DAYTON AUDIO DS175-8 Designer Series Speaker Driver Woofer / Midbass 70W 8 Ohm 88dB 40Hz - 4500Hz Ø16.5cm
DAYTON AUDIO DS175-8 Designer Series Woofer Speaker 8 Ohm Ø16.5cm
The Dayton Audio DS175-8 is a bass speaker belonging to the Designer Series range. A range specially designed to meet the needs of speaker designers.
Reference : 12761
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Designer Series Woofer Speaker 8Ω Ø 16.5cm
Designer Series
The Dayton Audio DS175-8 is a bass speaker belonging to the Designer Series range. A range specially designed to meet the needs of speaker designers. This incorporates attractively priced speakers, while putting performance first. The careful engineering brought to this range allows each loudspeaker to manage the maximum rated power at the lowest possible frequencies, and this without exceeding the Xmax (maximum linear excursion) in order to preserve the speakers.
So these speakers combine excellent audio performance with elegant styling. Optimized to provide faithful sound reproduction when installed in a wide variety of enclosures, the Designer Series speakers provide an excellent audiophile solution.
Woofer DS175-8
The DS175-8 woofer offers very interesting performance for mounting a quality audio system. Its large travel capacity allows it to offer deep bass. Soft frequency response and linear reduction simplify filter design, even ensuring good results with ready-to-use filters. In addition, the speakers are optimized to provide a low point of 3dB and high efficiency, even in a small body size. Finally, the materials include a coated paper membrane and a rubber suspension for great durability.
Speaker SerieDesigner Series
Speaker typeWoofer
Nominal diameter6.50" (16.5cm)
Power Handling : RMS70W
Power Handling : Max140W
Impedance
Sensitivity87.7dB 2.83V/1m
Frequency response40Hz - 4500Hz
Voice coil diameter35.5mm
Magnet weight935g (33oz)
DC Resistance (Re)5.7Ω
Voice coil inductance (Le)1.06mH @ 1kHz
Resonant frequency (Fs)37Hz
Mechanical Q (Qms)1.63
Electromagnetic Q (Qes)0.32
Total Q (Qts)0.27
Diaphragm Mass Inc. Airload (Mms)26g
Mechanical Compliance of Suspension (Cms)0.71mm/N
Surface Area of Cone (Sd)128.7cm²
BL Product (BL)10.4Tm
Compliance equivalent volume (Vas)17l
Maximum linear excursion (Xmax)5.25mm
Cone materialCoated paper
Surround materialRubber
Voice coil wire materialCopper
Voice coil materialAluminium
Basket materialSteel
Magnet materialFerrite
Overall outside diameter175.6mm
Overall depth80.6mm
Cutout diamter144mm
Fixation holes5
Speaker Power (W RMS)70.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)40
Highest frequency (Hz)4500
