MONACOR SPH-135 / AD Bass speaker-medium 13cm Hi-Fi 60W 8Ω
Monacor SPH-135/AD
Reference : 826
48,70 €tax incl.
40,58 € tax excl.
This product is no longer in stock
60 W MAX , 8 Ω Hi-Fi Bass-Stereo Speaker
Carbon fiber membrane, long life rubber suspension, Kapton support, flat wire technology, oversized magnet, kernel decompression. For 2-way systems, close or bass-reflex load, decorative crown.
yl = "font-family: Verdana; font-size: small;">
Impedance (Z)8 Ω
Fresonance frequency (fs)39 Hz
Maximum bandwidthf3-6000 Hz
Freq. cut. (fmax).5000 Hz
Maximum power60 W MAX
Rated power (P)40 W RMS
Pressure sound. (1W / 1m)89 dB
Compliance susp. (Cms)2.14 mm / N
Moving mass (Mms)7.8 g
Mechanical resistance (Rms)0.6 kg / s
Mechanical overvoltage. (Qms)3.40
Electrical overvoltage (Qes)0.42
Fact. total surge (Qts)0.37
Volume equ. (VAS)26 l
DC resistance. (Re)5.5 Ω
Inductance coil. (The)0, 47 mH
Coil diameter25.5 mm
Coil holderKapton
Height winding9.5 mm
Air gap height6 mm
Linear Excursion (X MAX )± 1.75 mm
Transmitting surface (Sd)95 cm 2
Flight. air displaced (Vd)16.6 cm 3
Force factor (BxL)5.0 Tm
Ref. (No)0.4%
Magnet diameter100 mm
Magnet Weight13.3 oz.
cuttingØ 121 mm
Mounting depth 70 mm
Dimensions135 x 135 mm
Weight1.1 kg
Recommended Min Volume
<img src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" />
closed10 l
bass reflex22 l
PDF-Download
</ A>
PDF-Download
Colissimo - TNT - SoColissimo
