AURALiC ARIES MINI HiFi Streamer ES9018K2M DAC 32bit 384Khz WiFi DLNA Airplay Black
AURALiC Aries Mini Hi-Fi Streamer ES9018K2M 32bit 384Khz White
The Auralic Aries Mini is a complete and powerful network drive, integrated into a compact and attractive housing. It will allow you to upgrade your audio system to provide more advanced connectivity and enjoy your audio files more simply and quickly.
Reference : 10741
499,00 €tax incl.
415,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Auralic Aries Mini
HiFi Streamer ES9018K2M 32bit 384Khz WiFi DLNA Airplay Black
Auralic Aries Mini DAP Sédentaire et Lecteur Réseau ES9018K2M 32bit 384kHz Noir
DAC ES9018K2M & Powerful CPU
The heart of the Aries Mini is its proprietary Auralic Tesla Quad ARM A9 processor running at 1GHz. This one, in charge of data processing and associated with the Auralic Lightning DS OpenHome interface (iOS 8 compatible), allows fast, smooth and extremely efficient navigation and reading.
The digital-to-analog conversion part is handled by a DAC ESS ES9018K2M chip supporting high sampling rates up to 32bit 384kHz in PCM and up to DSD256. This chip uses the 32bit HyperStream architecture and Time Domain Jitter Eliminator technology, giving it a nice dynamic, THD+N of -120dB while significantly reducing jitter.
Connectivity
One of the strengths of the Aries Mini is undoubtedly its connectivity. Indeed, it offers an RJ45 Gigabit port as well as WiFi support, to allow you to access files stored on devices on your local network (computer, NAS, smartphone...). There is also a space to accommodate a 2.5" hard disk (not provided).
The device is also compatible with many streaming services such as Qobuz, Spotify Connect, Tidal and Internet radios. This way you can enjoy your favorite service to listen to your music simply. In addition, the Aries Mini is compatible with DLNA/UPnP and AirPlay protocols to allow you to easily stream your audio files from your smartphone.
On the output side, there is a S/PDIF Coaxial connector, Toslink Optics, stereo RCA and a USB-B 2.0 output to connect an external DAC and give it the advanced connectivity of the Aries Mini.
The performance of the Aries Mini can be increased by using a Auralic PSU optional line power supply. The latter provides better stability of the sound stage and refinement of harmonics in the midrange and treble.
Video review of the Auralic Aries Mini by The Hans Beekhuyzen Channel
Auralic Aries Mini review by Qobuz
" The Auralic Aries Mini streamer is a modern device that offers a wide range of settings and reading capabilities, resulting in very good sound quality on its analog outputs. "
Test du Auralic Aries Mini par Qobuz
Technical charcateristics
Product typeStreamer
Inputs1x RJ45 Ethernet Gigabit
WiFi Dual Band
1x 2.5" Hard Drive Slot (not included)
OutputsUSB-A 2.0 for audio DAC
1x S/PDIF Coaxial
1x Optical Toslink
1x Stereo RCA
Supported sampling ratesUSB : up to 32bit 384kHz
Coaxial : up to 24bit 192kHz
Optical : up to 24bit 96kHz
Compatible streaming serviceQobuz
Spotify Connect
Tidal
Radios internet
AirPlay
Software interfaceAuralic Lightning DS OpenHome, iOS 8 compatible
Compatible media serversMinimserver
Twonky Asset UPnP
Jriver
DLNA/UPnP
AirPlay
Supported audio formatsAAC, AIFF, ALAC, APE, DIFF, DSF, FLAC, MP3, OGG, WAV, WV, WMA
Power supplyVia Jack DC 5.5/2.5mm connector
Max consumption10W
Dimensions135 x 135 x 28mm
Weight500g
InputWiFi
InputRJ45
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
Max sampling rate384kHz
Max sampling rateDSD256
2 reviews
Excellent streamer, à condition d’avoir un bon réseau. Très bon Dac. Produit au remarquable rapport qualité/prix.
Il me fallait un système compact et qualitatif ayant la capacité de streamer Qobuz.
Avant toute chose, il faut disposer d’un bon réseau pour utiliser cet appareil, sous peine de difficultés dans l’installation, le fonctionnement, la création des libraires, la rapidité des commandes et bien sur le streaming (mon Macbook pro / Audirvana fonctionne très bien avec un moins bon réseau que l’Aries mini).
Si le réseau est bon (fibre, bon wifi…), aucun souci !
Cet appareil est remarquable pour son prix. Il stream parfaitement (Qobuz HR pour moi). Plus besoin d’un ordinateur. On évacue donc le souci du « bruit » que celui-ci génère sur le signal musical (même s’il est relativement facile maintenant de pratiquement l’effacer). L’Aries mini peut servir de serveur en lisant un disque dur externe, ou bien son disque dur interne si l’on en met un (j’ai placé un disque SSD de 1 To qui contient mes 20 000 titres). Il peut ‘driver’ un DAC externe, ou bien possède son propre DAC avec contrôle du volume digital donc est autonome en tant que streamer/DAC/préampli. Je l’utilise maintenant dans cette configuration, où il alimente un ampli de puissance stéréo de bonne facture.
Pas de différences réellement notables constatées sur la sortie USB ou coaxiale (en fait, on distingue surtout la qualité d’entrée du DAC derrière ! L’Amanero USB du Master11 par exemple sonne mieux que la coaxiale. Pas de différence flagrante entre l’USB et la coaxiale d’un Fostex HPA8 quand le réseau est bon par exemple).
Au sujet du DAC, si j’ai évidemment préféré le son de mon Audio-GD Master-11 alimenté par l’Aries mini comme streamer seul, le DAC embarqué (ESS Sabre 9018K2M) est très bien implémenté et produit un son d’excellente facture, du niveau des DAC de la gamme 400-800 euros. J’ai pu comparer avec 2 bons DACs comme le Fostex HPA8, et l’Aries mini s’en sort remarquablement. Beaucoup de détails, une bonne scène sonore, bon niveau de basses, du liant dans la musique, belle dynamique. Il produit un son sur la finesse, peut être un manque de ‘corps’ mais c’est une question de goût. Les filtres numériques ne sont pas un gadget et permettent d’optimiser le rendu musical en fonction de son goût ou de sa pièce d’écoute (influence sur les hautes fréquences). C’est subtil mais efficace. Le contrôle digital du volume me semble très bon car je n’ai pas noté de perte flagrante de dynamique à volume faible ou modéré !
Pour information, je possède aussi un Bluesound Vault (première génération) et la musicalité de l’Auralic est très supérieure. J'ai d’ailleurs relégué le Bluesound au rand de ripper seul car je n’étais pas satisfait de son rendu musical (belle chaleur mais un peu « brouillon », perte de dynamique à bas volume).
L’application Auralic est simple, fonctionnelle, rapide (si on a un bon réseau), conviviale. Elle a quelques zones d’amélioration (je préfère Audirvana, peut-être y suis-je plus habitué) mais rien qui n’empêche de rapidement écouter les morceaux que l’on désire, sur Qobuz ou sur les musicothèques locales.
Je vis donc la musique avec plaisir sur ce système compact que je devais constituer dans un nouveau (petit) appartement. Ce n’est certes pas au niveau de mon système principal qui a beaucoup plus de place pour respirer, mais c’est vraiment très bien et supérieur aux ‘grosses’ chaines avec lecteur CD que j’avais il y encore 3 ou 4 ans. Que de progrès ont été réalisés !
Bref, un excellent appareil, car à mon sens, on a pour le prix un excellent streamer et un très bon DAC. Cela pourrait valoir le double !
A noter que je l’utilise l’alimentation linéaire. J’ai tout de suite entendu la différence entre l’alimentation standard et l’alimentation linéaire (plus de précision dans le placement des voix et instruments) en écoutant mon Master 11 pourtant commandé à un Mac Book pro (Le Master 11 et l’Aries mini partageaient la même multi-prise) !!!. Je pense que la petite alimentation interférait avec mon Master 11. Je n’ai donc même pas comparé l’Aries mini en tant que Streamer/DAC avec ou sans l’alimentation linéaire. Je ferai l’expérience mais je serai surpris que l’alimentation linéaire ne fasse pas une différence, alors que j’ai entendu son influence sur un autre appareil ! Néanmoins, sur un système moins résolutif, on doit avoir plus de difficulté à faire la différence
This review has been posted for AURALiC ARIES MINI HiFi Streamer ES9018K2M DAC 32bit 384Khz WiFi DLNA Airplay Black
Conquis !
J' ai pris l' alim optionnelle auralic, il est relié à un DAC audio GD NFB1 en USB et un SSD de qualité y a trouvé place......l' écoute est tres agréable, tout est là, vraiment je suis enchanté du résultat ! meme les radios internet en 128 kb sonne plus que convenablement.
The Auralic Aries Mini is a complete and powerful network drive, integrated into a compact and attractive housing. It will allow you to upgrade...
