This sleeve is both beautiful and high quality. Will buy again.
Braided sleeving made from single-strand PET (Polyethylene Terephthalate) that can be used in a wide variety of applications. Thanks to its expandability, the unique braiding of PET allows it to be installed quickly and easily on bulky and irregularly shaped connectors.
The PET is braided from a 0.010'' monofilament of PolyEthylene Terephthalate for continuous use at temperatures between -40°C and 125°C. Its melting point is 210°C. It has good dielectric qualities as well as excellent tensile strength and good elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computing, scuba diving, electronics, electrical harnesses, audiovisual, and even certain military applications.
"Gloomy Brown" color, subtle combination of brown, cream and black stripes, exclusive to the ELECAUDIO brand.
ATTENTION: Depending on the diameter of the cable the effective length of the sheath can be reduced by up to 20%!
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER | |
Cable diameter | Required sheath length |
Ø7mm | 1m |
Ø8mm | 1.08m |
Ø10mm | 1.15m |
Ø12mm | 1.3m |
Ø14mm | 1.7m |
Spécifications :
Color | White |
Color | Black |
Color | Brown |
Material | Nylon |
Length (m) | Sold by length |
Max cable diameter (mm) | 14.0 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Srboljub S.
Gilles C.
