DIY Aluminum Aluminum 8 ports Schuko Black
Multiprise DIY aluminium 8 ports Schuko
4.3 / 5
Reference : 3451
58,90 €tax incl.
49,08 € tax excl.
Available
Shipping date: 25-02-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
DIY Aluminum 8 ports SCHUKO
It is used for the manufacture of high-end power strip
Allows connection of 8 Schuko sockets and polarity reversal
Aluminum Power Supply
A solid foundation for powering your HiFi system
With brass rails of very large section (about 6 mm ²).
This power strip is supplied without mains cable
You can find high quality cables for easy mounting right here.
Note that for most high-end power cables the input of the power strip will have to be enlarged, as the input diameter is 9mm.
  • Aluminum
  • Made in Germany
  • Supplied without mains cable
  • Length 490mm, width 60mm, height 45mm.
Having had several requests on the connection of the cables on the power strip here is the method:
Disassemble the 4 SCHUKO bases
Open the power strip in 2
Unscrew the ground nut on the inside so that the bases can be slid.
Once the first socket outlet you will discover a terminal block actuated by the screw present on the top of the "rails"
Colissimo - TNT - SoColissimo
7 reviews
Super son et rapport qualité prix imbattable
Sur mon installation HDG et en comparaisons de multiprises aux prix délirants (Revendues), nette amélioration de la qualité sonore a condition de mettre un cable standard de 2.5 carré minimum, surtout non blindé, et une bonne prise schuko.
Apport d'un grave trés ferme et d'un medium analytique.
Raccordement trés facile, aucune difficulté rencontrée.
This review has been posted for DIY Aluminum Aluminum 8 ports Schuko Black
montage
nul besoin de souder, il suffit de mettre les fils dans les bornes et de visser...
Bonne barrette mais pas facile à mettre en oeuvre
Bonne barrette tout alu de superbe qualité de construction. Monté avec câble WM-Audio Tornado, il faut jouer de la lime pour que ça passe et penser à voir large pour ne pas abîmer la gaine thermo au passage. J'ai du également trouver des vis un peu plus grande pour serrer le câble. Celles fournies sont un peu juste. Le bon qualitatif est évident par rapport à une barrette Axon (déjà de bonne qualité). J'ai gagné en dynamique et surtout en silence de fonctionnement. Moins de plop au changements de source sur intégré à lampe et recul du bruit de fond. En revanche, si vous n'êtes pas un pro de la soudure ou si vous n'êtes pas bien équipé, vous allez vous arracher les cheveux pour fixer les câbles au rails en laiton. J'ai finalement opté pour un vissage des câbles en bidouillant un peu. En espérant que cela tiendra dans le temps.
j'ai branché les deux barrettes avec des câbles YARBO SP-1100PW. Pour le montage il faut bien-sure agrandir le trou d'entrée et ne pas perdre son calme pour souder le câble sur les lames en cuivre.
Donc, en dehors du fait qu'il faut agrandir l'orifice d'entrée et qu'il n'y est pas de point de fixation dédier.
Le corps en alu coupe bien du rayonnement secteur et les fiche mal sont plutôt bien tenu.
pour l'ensemble : construction prix et pour le montage (mal pratique pour les non bricoleur ou personne mal équipé) 4 étoiles
Très bon produit pour le prix, montée avec du Yarbo 7000 (il faut un peu jouer de la lime mais ça passe) et une prise SCHUKO FURUTECH FI-E-35G Gold ; ça donne de la matière, de la fluidité, et de la douceur à mon système.
