Module Kit differential balanced XLR symetrizer DRV134 stereo
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 20-03-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
This audio module makes it possible to symmetrize all asymmetrical line level HIFI RCA CINCH signal in symmetrical signal (Balanced-XLR) in an autonomous and qualitative way. Equipped with quality passive components, the signal is processedand symmetrize by the classic AOP Balanced line Driver DRV134.
Moreover, these AOPs on DIP 8 support make it possible to modify the sound at will by a simple change. Various AOPs are pin-to-pin compatible based on the DRV 134, for example: THATS 1646.
It is suitable for the following assemblies and figures:
  • Audio sources on CINCH-RCA analog output (CD players, BluRay, DAC) to studio and sound devices, eg mixing tables with balanced inputs.
  • Home theater or HIFI preamplifier with RCA outputs to professional amplifiers with balanced XLR inputs.
  • HIFI preamplifier with RCA outputs to HIFI High-End Audio amplifier high-end XLR balanced.
Pto operate, this module requires a low noise AC 230V transformer to secondary winding 18V 0 18V AC or 12V 0V 12V AC. The symmetrical control part is filtered by an LM7912, LM7812.
On can also use a positive and negative (+/-) DC regulated power supply of 15V.
Features:/ Strong>
  • Asymmetric stereo module line-to-symetric with gold-plated XLR connector
  • Connection of inputs / outputs / power supplies by screw terminals
  • Map provided assembly
  • Supply voltage required Voltage AC 12 to 18V (12V AC recommended)
  • AOP Balanced Balancer Output Driver DRV134
Dimensions and weight:
  • Dimensions: 121 x 100 x 80 mm (L x W x H)
  • Mounting bracket for spacers not included: 100 x 95 mm
  • Weight: 74 g
mesure DRV134
ConnectionA brancher
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
