AUDIO-GD VACUUM 1 XLR Balanced Tube Preamplifier 6H2N-EB / 6U4N-EB
The Master 1 Vacuum XLR is a 100% tube preamplifier: the power supply stage and the preamplification / buffer stage are built exclusively from lamps, resistors and capacitors. In other words, it is a pure tube design developed specifically to offer the best of this technology.
By buying this product you get 219 loyalty points
Reference : 14153
2 190,00 €tax incl.
1 825,00 € tax excl.
Shipping from France
Billing in France
Technical support in France
Audio-GD Master 1 Vacuum XLR
Audio-GD Master 1 Vacuum XLR Préamplificateur à Tubes Symétrique 6H2N-E / 6U4N-EB
The Master 1 Vacuum XLR is a 100% tube preamplifier: the power supply stage and the preamplification / buffer stage are built exclusively from lamps, resistors and capacitors. In other words, it is a pure tube design developed specifically to offer the best of this technology. The Master 1 Vacuum will delight audiophiles who want to regain the characteristic sound signature of tubes, without sacrificing the transparency, dynamics and tonal accuracy of high-fidelity devices.
100% Tube Preamplifier
In accordance with the Audio-GD tradition, extreme attention is paid to channel separation. The device is divided into two individual circuits composed of 4 completely separate amplification channels, processing the balanced left and right signals. With the right choice of carefully matched lamps, this configuration helps to open the sound scene considerably without altering the transparency of the signal.
SOLEN film capacitors are in charge of filtering the power supply and signal. This type of component is particularly suitable for use in a tube preamplifier design.
In order to offer the tube sound in all its depth, Audio-GD has refrained from using a whole class of components likely to colour the signal and nuance the effect of the lamps. The circuit consists only of low-capacity film capacitors (no high-capacity electrolytic capacitors), no shock chokes, no power regulation: just the sound of the lamps.
The power supply stage itself is exclusively designed from tubes, which definitively eliminates any possibility of degrading the harmonics of the tube architecture with the noises of a transistor-based power supply.
Designed as a true modern high fidelity tube preamplifier, the Master 1 Vacuum has a low gain input that is highly engineered to work without compromise with current sources (which already have a high output level).
The circuit operates with 6 tubes 6H2N-EB and 4 tubes 6U4N-EB. This lamp model was developed by the Russian Air Force. It offers a very high level of precision and excellent durability.
Optimized volume control
Volume control is achieved by two relay switches (one per channel), which prevents signal degradation due to the presence of a potentiometer between two stages.
Designed to optimize performance and reduce distortion as much as possible, volume control works according to an unusual model. A first attenuation (always controlled by relays) takes place directly at the input of the preamplifier. This ensures that the signal will remain at an optimal level in accordance with the tube specifications. A second attenuation, located this time at the output of the gain stage, maintains the signal level in an optimal range for the power amplifier. In order to have a sufficient headroom, two tubes connected in parallel after the buffer stage allow the signal to be stabilized in configurations requiring a high output level.
Because this is a particularly sensitive stage, the boards responsible for volume control are isolated under a copper housing to avoid interference capture.
One consequence of this type of arrangement is that the signal-to-noise ratio varies with volume. This does not mean that performance is erratic, but on the contrary that the Master 1 Vacuum is optimized to provide the best possible signal-to-noise ratio in the output levels adapted to modern HiFi channels.
Another consequence of this architecture is to promote the accuracy of the signal at low volume. The alternation of attenuations makes it possible to massively increase the volume of the input signal (before the noise is captured) and then attenuate it to a traditional level, which leads to dividing the noise by the same order of magnitude.
This special design allows a first signal preamplification upstream of most noise sources, significantly improving the signal-to-noise ratio and resulting in performances rare in the world of tube preamplifiers, while respecting the signature of this technology as a whole. The Master 1 Vacuum thus displays a THD+N of less than 0.02% with a disconcerting linearity.
Metal remote control
The Master 1 Vacuum is delivered with its metal remote control, brushed aluminium finish. You will find 2 buttons to switch between your different sources, as well as 3 buttons to adjust the volume: Plus / Minus / Mute. A functional and refined accessory that reflects the elegance and sobriety of Audio-GD.
Wide connectivity and source selection
The Master 1 Vacuum XLR is the cornerstone of an analog section, with three balanced XLR and two unbalanced RCA inputs. The remote control allows remote source changeover, which can also be done from the buttons on the front of the unit.
At the output, the device offers a balanced XLR output, an unbalanced XLR output and an unbalanced RCA output.
Product typeTube preamplifier
Tubes6x 6H2N-EB
4x 6U4N-EB
Tube filament voltage6.3V
Burn in time100h in factory
Another 100h recommended
Warm time20min
SNR> 96dB (2V input, 2Vrms output)
Output impedance< 300Ω (RCA)
Input sensitivity280mV (1Vrms output)
Gain11dB
Voltage supply200-250V AC
Consumption35W
WeightApprox. 16kg
Dimensions430 x 430x 93mm
Housing materialAluminium
Package1x Audio-GD Master 1 Vacuum XLR
1x Power cable
Frequency response
THD+N (<0.02%)
THD
SNR on balanced output, volume 10 (109dB)
SNR on balanced output, volume 30 (107dB)
SNR on balanced output, volume 50 (102dB)
SNR on balanced output, volume 70 (98dB)
SNR on balanced output, volume 90 (93dB)
InputXLR
The Master 1 Vacuum XLR is a 100% tube preamplifier: the power supply stage and the preamplification / buffer stage are built exclusively from...
