WBT-0102Cu RCA Connectors Nextgen Copper 75 Ohm Ø9mm (Set x4)
WBT-0102Cu Connecteurs RCA Nextgen Cuivre (x4)
The basic element influencing the sound quality of the WBT-0102Cu is the central contact, here using pure Copper, chosen for its excellent electrical conductivity, guaranteeing perfect signal transmission. This contact is gold plated to give it a high resistance to oxidation.
Reference : 8644
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
WBT-0102Cu
RCA Connector Nextgen Copper 75 Ohm Ø9mm (Set x4)
WBT-0102Cu Connecteur RCA Nextgen Cuivre 75Ohm Ø9mm (Set x4)
The WBT-0102Cu supports a transmission bandwidth of up to 200MHz, a much higher value than traditional RCA plugs.
The clamping system, functioning like the chuck of a drill, allows a firm hold of the connector. The maximum contact pressure not only ensures a secure connection but also minimizes transition resistance.
The two-part clamping tube ensures that no part of the connector can move so that the contact areas are not exposed to torsional pressure. In addition, this method compensates for potential inaccuracies in the dimensions of the outer contacts of the sockets.
The center pin is split and slightly bent to ensure a secure and durable connection with the lowest possible transition resistance.
The body of the connector is made of a copper alloy with gold plating and can accept thick, rigid cables. The metal body is, of course, electrically insulated from the contact area and uses a very small amount of metal to cancel eddy currents.
Finally, the WBT-0102Cu has electromagnetic shielding, which is particularly important for analog connections.
1Contact +
Pure Copper
2Contact -
Pure Copper
3Ultramid dielectric
4Vectra S135 dielectric
5Holding unit
Copper alloy
6Shaft of clamping barrel
Copper alloy
7Head of clamping barrel
Copper alloy
8Marking ring
Desmopan
9M4x4 Torx screw
Copper alloy
Product typeRCA Connectors
Contacts materialPure Copper
Contacts platingPure Gold 0.5µm
Dielectric materialUltramid, reinforced with glass fiber
Vectra S135
Body materialCopper alloy
Holding unit platingGold
Body platingDual layer Chrome
Mounting typeTo solder
Max cable diameterØ9mm
Permanent currentID > 10A
Transition resistanceRü < 0.1mΩ
Contact resistanceRBi, RBa < 0.45mΩ
Self capacitanceC ≈ 2.82pF
Insulation resistanceRia, RaG > 1.3x109
Characteristic impedance75Ω
External dimensionsØ13.6 x 51mm
Internal diameterØ9mm
QuantitySold by 4 (2 units with white ring, 2 units with red ring)
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
The basic element influencing the sound quality of the WBT-0102Cu is the central contact, here using pure Copper, chosen for its excellent...
