SUPRAVOX 215 GMF - 21 cm - 97 dB - 45 Hz / 5 kHz
Supravox 215 GMF - 21 cm - 97 dB - 45 Hz / 5 kHz
By buying this product you get 38 loyalty points
Reference : 29
389,00 €tax incl.
324,17 € tax excl.
This high-bandwidth, high-output loudspeaker offers you a very fast and pleasant listening. Ideal listening with a low power amp (tube or transistor) of about 10W, it also supports higher powers for use in subwoofers. In a flat panel, it will reinforce the 215 RTF with the same degree of reproduction precision, to add a bass reinforcement and ensure a comfortable and balanced listening. In column TQWT it will bring out all the finesse of your favorite listening. In case RJ, bass reflex or symmetrical, it will be a grave of accompaniment of the most precise. This HP can be coupled with a 1-inch engine mounted on our horn. Cut to 500Hz the response curve will be straight to ± 2 dB from 35 to 20 000Hz.
Colissimo - TNT - SoColissimo
