SUPRAVOX 165 EXC - 16 cm - 90 to 95 dB - 60/20 kHz
Supravox 165 EXC - 16 cm - 90 à 95 dB - 60 / 20 kHz
By buying this product you get 58 loyalty points
Reference : 42
589,00 €tax incl.
490,83 € tax excl.
It has a mobile crew and a response identical to 165-2000.
Its advantage is the possibility of adjusting these parameters thanks to a powerful electromagnetic motor. Adaptable to many speakers, it requires an external power supply.
Sensitivity 1 W / 1m to Fs90 to 95 dBFood0 to 10 Volts DC.
Bandwidth60 to 20 kHz-family: Verdana, Arial, Helvetica, sans-serif; font-size: small; "> Magnetic field0 to 2 T
Impedance4 ohmsHP Diameter185 mm
Power consumption RMS35 WBowl ThicknessAlu 10mm
poids3.2 kgDistance fixing holes175 mm
Suspension5-ply paperDrill hole diameter160 mm
Resonance Frequency78 Hz HP Depth 95 mm
Linear Excursion+/- 5 mmsd
165 cm²
fs
mms
Cms
Re DC
78 Hz
4 g
1
4.1
Food
5 V
6 V
7 V
8 V
9 V
10 V
Vas36.438.638.83839.639.5
qt
1.6
1.2
1.07
0.9
0.87
0.8
Qe
1.9
1.4
1.15
1
0.95
0.85
Qm
10.66
10.73
10.6
10
9.77
10.1
bl
2.57
2.9
3.2
3.47
3.48
3.63
SPL ref
91.5>
93.1
93.9
94.5
94.8
95.1
Colissimo - TNT - SoColissimo
