Tomasz C.
arnaud m.
Exelent
Jean-Louis R.
ne chauffe plus assez
Avis clients - Il y a 19313 avis.
Zeferino I.
Encodeur Numérique Rotatif 24 Positions Bouton Poussoir Axe Méplat Pré-Soudé Cet encodeur rotatif propose une incrémentation sur 24 positions et dispose d'un axe méplat (D-Shaft). Utile pour de nombreux projets DIY, il peut notamment...
Rotary Digital
The part is very well made and ordered it for the AUDIOPHONICS DAC I-Saber ES9038Q2M .....
The function has yet to be tested ....
Zeferino I.
Ecran OLED 1.3"
The Oled Display works very well
Zeferino I.
Very good DAC card
The DAC card I use with a Raspi 4 4GB.
The card I use with WebRadio V2 current version 0.3.9 and must say really that it works very well ...........
Gilles H.
C'est simplissime !!!
Alors là , c'est le truc HIFI esthétique, physique et sonore incroyable pour moins de 150 euros !!! ALLO y'a pas photo, c'est adopté !!! Bien venue chez moi au coté de mes amplis, REGA, MUSICAL FIDELITY, QUAD, CYRUS, AUDIOANALYSE,ALCHEMIST,SANSUI,NAD, ... et tes potes d'audiophonics : Quinpu q2, Ipar, Dayton...
Gilles
Sjoerd W.
Another outstanding Audiophonics product
I’m planning to assemble a DIY with of the shell components/board on this site, but I was struggling what to do with the USB-input. I have used a Audiophonics DAC AK4495SEQ for a year now. Amazing value for money, but the DAC has its limitations. Most noticeable is the digital glare/blur in the high register. On Back Friday I was searching for options on this site and came across this U208 interface and ordered it. It was neatly delivered to to me in the Netherlands a couple of days later. The box has an all black finish instead of silver/black, but you won’t hear me complain about that.
I tested this U208 interface in combination with the DAC I mentioned above using an Audiophonics coax cable and an Audiophonics USB-cable. Well that was interesting. The U208 just lifted this DAC to a whole new level. With this interface the DAC became far more natural, detailed, involving, lively …. and … well ... just a lot more fun to listen too. It just shows that good USB-conversion is difficult and doing it in a separate box with more room for good components and a separate power supply is very rewarding.
Bjarne K.
ARMATURE HECATE LT Interface USB SPDIF XMOS Xcore 208 Asynchrone TCXO Armature propose désormais son excellente interface USB SPDIF XMOS dans une version simplifiée mais toujours très performante, permettant de la...
B. Kjeldsen
Simple and easy product! Do a really good job between the mac and the dac in my setup. And thumbs up for audiophonics customer care!
Isaku H.
Great performance at reasonable price
With a recommendation from my audiophile friend, I purchased DG-201s to replace RCA plugs from a well know brand that costs almost 4 times as much. I was dumbfounded by how different the sound was and how much it improved to my liking. They are natural and a bit warmer side of neutral. Sound is musical and very enjoyable but also meets the audiophile requirements . Highly recommended!
Daniel C.
PACK Enceintes Bibliothèques DAVIS ACOUSTICS MIA 20 + Amplificateur FX-AUDIO XL-2.1B Ce pack se compose d'une paire d'enceintes bibliothèques deux voies Davis Acoustics MIA 20 et d'un amplificateur FX-AUDIO XL-2.1B. Il constitue ainsi un système...
Le matériel chinois m’étonneras toujours
FX-AUDIO D302 PRO entièrement plug and play aucun drivers usb a installer même sous XP, déactive toute la couche audio du pc pas dommage.
la qualité du son est égale voir supérieur a mon ampli NAD C658 de 10kg , avec la puissance en moins , mais largement suffisante pour sonorisé un salon de 75m²
les enceintes Davis bonnes pour leurs dimensions, rendement pas terrible les basses manque de définition, pour ce prix il ne faut pas rêver non plus .
Yoann L.
le meilleur que j'ai écouté
Bonjour, je post mon humble avis.
matériel : quad 606 mk2 , dali ikon 6 mk1, et ce dac en fonction dac-pré ampli.
ayant testé ce le micromega de mydac et le smsl su8, je peut vous dire que ce dac est juste énorme en timbre. ne pas lésiné sur les cable usb.
la vivacité de ce dac est juste exceptionnel. on entend vraiment tous les instruments sur des morceaux "rapide".
bref, je recommande les yeux fermée
Hugo W.
Hugo W.
Hugo W.
Brol !!! de goedkoopste brol ooit gezien,als u de kabellippen dichtklemt maakt u kortsluiting !!!
I don't understand what the connector has to do with a short circuit ? this design is common to 90 % of the Cinch connectors. i think you've forgotten to insulate them with a thermal sleeve.
Olivier P.
Livré en temps et heure. Fait le job (télécommande Logitech sur freebox révolution. Je recommande
Joerg P.
AUDIOPHONICS DAC I-Sabre ES9038Q2M Raspberry Pi / I2S & SPDIF / PCM DSD Alimentation Micro USB Audiophonics vous propose le successeur du DAC I-Sabre 9028 embarquant cette fois la puce de décodage ES9038Q2M. Cette version offre des performances sonores...
recommandation d'achat
Un des meilleurs Dacs que je possède. Son très clair et discret, graves profonds et très nets. La seule chose qui est ennuyeuse, c'est la LED bleue qui clignote constamment.
Andy H.
Nice XLR Connector
Hi, Salut, Nicely made simple connectors. Inexpensive, easy to work with and light weight aluminum body. **Care must be taken when soldering. Be quick as the contact support plate can be melted easily**
Andy H.
Nice XLR connectors
Andy H.
Excellent IC Cable
Hi, Salut,
Pros: A very smooth, highly detailed cable. Excellent value for your money. Light and flexible. Small outer diameter
Cons: Not as easy to work with as some cable. Each conductor is wrapped in teflon tape under its PTFE insulation. It is somewhat difficult to remove for soldering. Cotton filler time consuming to trim back.
Patience is also required for it to sound it's best. Allow 100+ hours for it to break in.
Thierry B.
Très bon état, aucune rayure.
Parfait état.
Ce coffret semble solide.
Le montage n'est pas immédiatement intuitif.
Thierry B.
ELECAUDIO DF-03 Gaine Tressée Extensible Nylon (PET) 06-16mm Gaine tressée élaborée en  PET (Polyéthylène Terephtalate)  monobrins pouvant être utilisée dans une large...
Très bon produit. Bonne fabrication. Facile à travailler.
Correspond à sa description.
Bastian B.
MINIDSP SHD STUDIO Processeur Audio Numérique DSP SHARC ADSP21486 Dirac Live Lecteur Réseau Volumio Le Studio SHD (pour  Streaming High Definition ) de MiniDSP est un Processeur Audio Numérique (DSP) embarquant la solution de correction acoustique Dirac Live. Une...
Good product - could be better
I really enjoy my new miniDsp DHS Studio. I use it as a roon endpoint. In my opinion it sounds not much better than my digi one. But the room correction is the key. This really improved my sound experience. I was looking for such a product for quite some time. And I am really happy with it.
I hope that miniDSP will improve the shd studio over time. There are quite a number of features missing. E.g. no way do dim the display and almost no configuration of the unit at all. Basically it is just "select source", "activate dirac", "select diract preset". Other products in the price range have much more configuration options.
The build quality is ok. But not amazing. I am not totaly happy with the volumne knob.
In total I am happy with my purchase. But there is room for improvement. Nevertheless, it does what I bought it for and it does it well. Therefore 5 stars.
jean-pierre a.
bt60w v2
bon tout petit ampli
Exceptionnel
Après 24 h sur le tuner pour le rider, j’ai associé ce câble avec des prises pur cuivre.
Le rendu est franchement exceptionnel sur l’ensemble des paramètres qui nous font apprécier un câble.
Je le compare avec des câbles type Siltech ou YBA et ce câble est franchement de même qualité voir peut-être mieux dans le haut du spectre qui me paraît plus fin moins métallique.
En 2x 1.50 m avec des fiches Rca moyenne game le coût final est 75€ avec une soudure argent 10%.
Je vais en recommandé pour équiper tout mon ensemble.
Il n’existe rien à moins de 3/400€ pour rivaliser
Faites vous plaisir
Patrick
Pour le prix c’est vraiment une très bonne affaire
Facile à souder et très bon contact avec les prises rca ampli/cd
Je recommande vivement
Rafail P.
Furutech FT-111
Livraison rapide et soignée. Le produit et relativement facile à monté - à condition d'avoir un peu d’expérience. J'ai monté les connecteur sur du cable QED Reference Audio 40. Résultat- plus de profondeur surtout pour les basses, sur de enceintes Audio Physic Spark et ampli Thule 60.
michel d.
excellent produit qui apporte réellement un plus; connecté a mon Xperia XZ3, le son est plus claire et détaillé plus dynamique quand au niveau de sortie c'est le top ....
Tomas C.
Excellent connectors
I am upgrading higher grade equipment (McIntosh, Musical Fidelity, Arcam, Kenwood (Trio)..) and was looking for great connectors to match level of equipment. Initially I thought WBT is something I have to have regardless of price. They are good but overpriced IMHO. If you check specification of WBT conenctors you will easily find that they are based on brass material - cheapest material that can be found on connectors with price of 1 dollar from China. It is so hard to find connector that is based on copper. These connectors fullfil my needs, very well manufatured and working amazing when restoring good old hifi components. Their price is also amazing. I highly recommend them! No need of looking for WBT anymore!
Marc T.
Métal mince : j'ai choisi de les sertir simplement sur le câble. Un peu délicat, mais on y arrive avec une déformation minime de la partie à insérer.
Les souder ? peut-être, mais au moins à l'argent : penser à la connectivité des métaux.
Pourquoi s'offrir des câbles en cuivre de très haute qualité si c'est pour terminer par de l'étain ou du plomb ?
Marc T.
Fourches économiques, pratiques, faciles à bloquer, mais :
-faire confiance au fabricant, car le cuivre me semble un peu blanc si on gratte...
-pourquoi laisser dessous une fente aussi large ? Perso, je les ai resserrées à l'étau
-peu adaptées à des câbles de moins de 2,5 mm2. J'ai rempli les vides avec d'autres bouts de cuivre...
J'attends un autre jeu pour comparer.
1877PHONO GC-09 Fiche Banane Verrouillables Noir Ø9mm (Set x4) Fidèle à son image de créateur "Haute Couture" en matière d'accessoires Audiophile, 1877 PHONO nous propose avec sa série GC des fiches...
Trés bonne qualité de fabrication. Robuste, esthétiques et efficaces.
Marc H.
Quelle pureté du son fourni par cette voie centrale.
Audiophonics est une société sérieuse. Les délais de livraison sont au top.
philippe D.
Fait le job !
Je m'en sert depuis 3 jours. Aucun pb, il fait le job.
A voir sur la durée s'il tient sur la longueur, mais pour l'instant c'est parfait.
gilles b.
Un super outil
Après avoir téléchargé volumio dédié à cette version de rapsdac la mise en route est un jeu d'enfant.
Volumio se prends bien en main, il manque quelques fonctionnalités, à voirie si on the peut les rajouter, côté son : comparé à mon couple dac drive cd linn le rapsdac fait très bien le travail, un son droit avec une bande passante très étendue à comparer au linn il lui manque juste un peu plus de " présence" de "matière",
À voir ce que apporte une bonne alim sur ce rapsdac.
Aucun regret donc d'avoir acheter ce modèle, je recommande vivement cette solution.
Dominique P.
IKKO ZERDA Adaptateur DAC USB-C vers Jack 3.5mm / Optique Mini-Toslink CS43198 32bit 384kHz DSD256 Le Zerda de Ikko est un adaptateur USB-C avec DAC intégré, idéal pour les audiophiles souhaitant utiliser leur smartphone nouvelle génération...
Excellent Produit
Branché en USB sur PC puis vers la sortie optique du Dac SMSL Q5 Pro
avec Enceinte DALI.
Application Foobar2000, Plugin WASAPI shared
Excellent son.
Pierre B.
Bon câble
Arrivé bien emballé et bien présenté, ce câble se révèle à l'usage transmettre une belle image et un bon son. Les connecteurs sont de belle qualité et la connection se fait parfaitement. Excellent rapport performance/prix.
Rodolphe D.
Exellent produit
Super petites cosses que j'ai utilisé pour le recablage interne de mes enceintes ,le son est parfait .Je suis content de mon achat Bravo
Jean B.
Possédant déjà le RT10 Rhodium-Argent pour la liaison Ampli-streamer et étant plus que satisfait, j'ai acquis le GT10 pour la liaison ampli-lecteur Blu-ray. Toujours le même plaisir avec une définition vraiment au-dessus du lot. Cette marque US assez confidentielle en France se signale aussi par une qualité de fabrication hors-norme.
Françis S.
AUDIOPHONICS DIGITAL AUDIO Câble USB-A Mâle vers USB-B Mâle Cuivre OFC 4N PTFE 2m Le câble USB Audiophonics Digital Audio est un câble numérique développé par l'équipe Audiophonics et assemblé dans nos ateliers....
Françis S.
En remplacement d'un cable standard tout à fait insatisfaisant , fonctionne non comme un filtre, mais dans l'ordre et d'une manière cohérente . Une bonne surprise face à mon septisme pour la musique qui sort d'un ordinateur . Un très bon produit .
Suite à un premier achat d’un potentiomètre commuté valant plus de 50€ .. j’ai essayé ce modèle bien moins cher ... et bien conclusion il es largement aussi bon ..piste ferme. Beaucoup de transparence . Un rapport qualité exceptionnel ..un très bon produit .
XDUOO 05BL PRO Récepteur Bluetooth 5.0 aptX HD LDAC pour XD-05 / XD-05 PLUS Le xDuoo 05BL Pro est une extension destinée aux xDuoo XD-05 et XD-05 Plus, permettant d'offrir à ces DAC / amplificateurs casque une connectivité...
Upgrade du 05BL précédent
Ayant testé les deux extensions Bluetooth sur le XD05 Plus, sur cette 05BL Pro j'obtiens bien la liaison en LDAC 96 kHz. Est-ce que cela apporte réellement à l'écoute comparé à l'APTX sur le 05BL précédent?
À mon avis pas énormément... un peu quand même.
Ça et l'ajout de l'AOP Burson V5i propulsent le XD05 Plus vers des écoutes vraiment agréables, addictives j'ai du mal à me décoller de cet appareil!
Si vous voulez l'extension Bluetooth sur le XD05, pour le même prix choisissez plutôt la BL Pro, pour le nombre de codecs compatibles. Elle a une prise usb-c pour la charge batterie, une autonomie un peu supérieure j'ai cru comprendre.
Très convaincant
Monté sur le XDuoo XD05 Plus. Cet appareil n'offre pas beaucoup de place pour monter d'autres AOP, un Sparkos Labs ne rentre pas par exemple.
Le Burson par rapport à l'AOP d'origine modifie pas mal l'écoute, en bien.
Le niveau de sortie est augmenté, je suis obligé de baisser nettement la commande de volume, avec le même casque.
Je trouve que ce Burson apporte de la dynamique, en même temps j'aime bien ses qualités de restitution générales, la finesse dans le médium aigu, l'équilibre. Les basses par exemple sur de l'électro comme Brol de Angèle sont bien là.
La spatialisation est très bonne également.
En comparaison, l'AOP d'origine qui est déjà très bon privilégie davantage le médium et me semble moins fin dans le médium aigu. Je n'ai pas envie d'y revenir, prenant vraiment du plaisir sur ce XD05+ avec le Burson!
Danielle a.
cables d'enceintes
parfait envoi très rapide très bon emballage materiel de très haute qualité
Jean-Marc F.
Du rapide!
Matériel reçu en 48h, pour une première commande, parfait. Concernant le produit, j'ai un bon ressenti, j'ai fait plusieurs changements en même temps sur mes câbles qui ont été absolument incroyables en terme de résultat, l'élément majeur ayant été mes câbles hp (Esprit Eterna ! ), mais ce câble a contribué au résultat final sans aucun doute. Je regarde maintenant si j'investis dans une barrette BADA pour le secteur!
Stéphane B.
Super efficace
Les PANGEA (mega et pico) sont sans aucun doute les accessoires les plus simples, les moins chers et les plus efficaces que j'ai pu utiliser en HIFI.
Ici, pas de grigri inventé par un géotrouvetout de pacotille et vendu plusieurs centaines ( ou milliers) d'euros, tout est dans la matière.
Je confirme tout ce qui a déjà été dit, à savoir que le sorbothane est redoutablement efficace pour découpler tous les appareils HIFI. J'ai placé des MEGA sous mes enceintes et mon ampli/dac et des pico sous mon drive. Le résultat est sans appel, plus de résonances désagréables dans les basses fréquences, graves plus propres et donc une sensation d'aération accrue. Super produit !
M. S.
AUDIOPHONICS HPA-S400NC Amplificateur de Puissance Class D Stéréo NCore NC400 2x400W 4 Ohm Ce bloc constitue une solution d'amplification possédant une réserve de puissance redoutable (jusqu'à 400W / canal) tout en respectant scrupuleusement le...
Excellent!
A remplacé très avantageusement un Atoll in200.
Très bon son, beau boitier, ne chauffe pas, prix correct. Qui dit mieux?
Bruno l.
Extraordinaire !!!!
Je l’ai branché entre mon PC qui pilote l’audio avec foobar et un dac Audio GD nfb 29, sur une chaîne en multi amplification classe D (Audiophonics!) avec des hauts parleurs extrêmes ( 38 multi aimant / medium iso dynamique / tweeter à ruban ).
Habituer à faire des centaines d’essais pour toujours progresser petits pas par petits pas, là je suis sur le cul ! Pas la peine de ramer, en 5 secondes sur la première intro de musique on prend une claque, c’est comme si on ouvrait les rideaux pour regarder dehors, tout est plus défini, plus large, plus profond, plus net, plus rythmé et mieux timbré.
Impressionnant ! Bravo à IFI
Rene V.
Ce microphone est immédiatement reconnu par le logiciel de mesure REW.
Le fichier de calibration, disponible sur le site du fabricant, ne corrige que relativement peu la courbe de sensibilité, preuve de la qualité de l'objet.
Aucun point négatif à signaler.
Rene V.
Bon hardware mais software étrange ...
Sur le MiniDsp en tant que tel, j'ai un avis très positif.
Le filtrage, bien réglé, apporte un plus indéniable sans amener trop d'inconvénients.
Le bruit de fond est inexistant et la résolution très satisfaisante.
Seul le volume de sortie (...) est en effet un peu faible même si les cavaliers sont correctement placés.
Par contre, où sont tous les plug-in promis dans le mode d'emploi ?
Vérifiez sur le site si le plug-in que vous recherchez existe toujours avant d'acheter.
Le logiciel peut avoir des réactions étranges comme confirmer une commande reset avec le MiniDsp non connecté !
Dans l'ensemble cela fonctionne bien.
Hervé B.
Un dac d'exception
Que dire..... Et bien que du positif hormis un seul point de cette magnifique oeuvre technologique.
Actuellement, je possède un XDUOO-TA10, et tout ce que je peux affirmer est que la on joue dans une autre cour. La reproduction sonore ainsi que la musicalité est sans compromis. On sent bien le matériel pro dans toute sa splendeur.
Un bémol cependant concernant la navigation dans les menus qui relève du parcours du combattant! Mais rassurez vous, on s'y fait petit à petit.
Bref, tous ceux qui achèteront cette merveille ne seront point déçus !
A recommander sans réserve aucune. Un best-off.
Jean Yves P.
Amanero usb 384 kHz
Colis bien emballè , merci .Mais fort mécontent du produit reçus car ne correspond pas à la documentation ni aux avis émis a savoir l'implémentation déjà faite de la puce d'alimentation. Je me retrouve donc hors de mes compétences et donc produits partiellement inutilisables .
Il semble en effet qu'il y ai un problème sur la dernière livraison.
Mes collaborateurs du SAV vont prendre en charge votre soucis dans la journée.
William R.
Réactivité et disponibilité au niveau des conseils de l'équipe (que je remercie au passage), expédition sans faille et produit impeccable. Parfait sur toute la ligne.
Aurelien G.
J'ai des enceintes compacte klipsch rp 160 avec un ampli onkyo, il étaient fatiguant voir agressif avec un câble lambda de 2.5. Franchement je ne croyais pas trop au miracle et après avoir essayé un hp avec l'ancien et l'autre avec le mogami le jour et la nuit doux dans les aigus des médium plus précis/percutant j'ai redécouvert mes morceaux préférés.
