Moyen
Elle se retourne en...
Giacomo P.
No for me
Absolutely no!
Gérard M.
Simple... efficace mais sommaire.
Très bon résultat sonore. Facilité de connexion. Ce qui aurait un plus c'est une alimentation fournie avec...
Avis clients - Il y a 20771 avis.
Andras S.
SMSL PL200T Transport CD USB XMOS 32bit 768kHz DSD512 MQA-CD Le SMSL PL200T est un transport CD performant et polyvalent. Il se base principalement sur un système de lecture Servo P.A.S.S (Precision Access Servo System)...
Small device - big sound
A very good sounding and funny transport. Compared to my Sony CDP-XA20ES (also used as transport) it has a bit more airy sound with bigger soundstage. Also sounds slightly better than my Holo Red streamer (with Volumio).
Positives: very good sound, superb finish, real plug & play (also with USB)
Negatives: extremely angle-sensitive remote with strange formed back panel, doesn’t read CD after switching from USB to CD input (needs restart), a bit shallow grip on the lid for bigger hands
M B.
AUDIOPHONICS HPA-S450ET Amplificateur de Puissance Class D Stéréo Purifi 1ET6525SA 2x450W 4 Ohm L'amplificateur de puissance Audiophonics HPA-S450ET se base sur une architecture classe D, utilisant une paire de modules Purifi 1ET6525SA, une alimentation Hypex SMPS1200A400...
Happy
I'll cautiously give this five stars. Replacing an old Marantz SM-80, this amplifier is astonishing, albeit only with room correction. On the one hand the Purifi controls the speakers much better than my old amp. The in-room loudspeaker response is measurably flat to within +/- 2dB over most of the range. This was not the case before. On the other hand there is a massive, one octave wide, almost 12dB bass bump, peaking at 80Hz. This may well be down to my speakers and their positioning at only 10 inches from the wall. However this effect is more pronounced than it was with my old amp, itself no slouch in the bass department. I ironed this out with room correction EQ, which turned out essential for my living situation.
That said, the precision and instrumental separation this amp wrings from my 30-year old Polk (not KEF) LS50 speakers has redefined what I thought those speakers were capable of. This amp is in a different league. The ability to hear into a recording now rivals that of my planar magnetic headphones. At the same time I find it less fatiguing than my old amp. It also performs much more evenly across my record collection. Records that previously sounded good still do, but the Purifi tends to bring up muddy and/or complex recordings to a similar standard. That's a big win.
If there is a downside, it's that on some recordings I find snare drums, and raspy sounds in general, a little too prominent. However that may be due to an interaction with my speakers or with the ability to better single out instruments in the mix, including drum kits and tambourines. The emphasis is that this applies to _some_ recordings only.
Coming from a 30-year-old amp, I of course find the value and performance of the Purifi hard to judge against it's peers, but I will say that it runs cool, Audiophonics' build quality seems good, the connectors appear of high quality, and the amp was well packaged and arrived on time. That said, while the power switch is satisfying and includes a ~2s relay delay, I can confirm the slight power on pop, more like a static click in the speakers, noted by another customer. It happens about a second after the relay engages the amp. There is also a small amount of coil whine, emanating from the amp while turned on, though only audible from a distance of about 1m or less while the house is quiet, at night.
Julien V.
SMSL PS100 DAC ES9023 USB SPDIF HDMI ARC Bluetooth 5.0 24bit 192kHz Le SMSL PS100 se présente comme un DAC abordable, performant et incroyablement polyvalent. Malgré ses dimensions réduites, le PS100 se base sur des...
Petit mais costaud
Acheté pour relier le décodeur TV Orange en SPIF pour essayer d'avoir un meilleur son.... et il le fait très bien.
La connexion en BT est très bonne aussi pour juste streamer vite fait de la musique depuis le tel ou l'ordi quand le streamer est pas dispo.
Le DAC est très bon et la définition détaillé. Le niveau de sortie est assez haut.
Frederic L.
Excellent rapport qualite/prix
Belle finition, 2 vis pour un contact sur et stable, et livrees avec gaines retractables. Que demander de plusc?!
Frederic L.
Tres satisfait
Gros diametre mais relativement souple, facile a denuder. Tres satisfait du rendu sonore avec ampli Primare i35 et enceintes B&W704 (neutre, dynamique, precis. ....). Pas de comparaison avec d'autres cables a l'aveugle.
Frederic L.
AUDIOPHONICS Gaines Thermorétractables pour Câbles 3:1 Ø18mm Noir (x2) Ce set de 2 gaines thermorétractable noires permet d'offrir à vos câbles une excellente finition avec un résultat propre. Le logo Audiophonics est apposé sur la gaine.
Utilises avec cable HP Canare 2F11S. Mise en oeuvre facile, la gaine se retracte rapidement et reste stable dans le temps. Permert d'obtenir une finition de cable tres propre.
David S.
Câble Symétrique pour Casque Jack 3.5mm vers 2x Jack 3.5mm Cuivre OCC Plaqué Argent 3m Ce câble pour casque audio dispose d'un connecteur jack 3.5mm stéréo symétrique et de deux connecteurs jack 3.5 mm symétriques. Le câble...
TOP
Fait le taf pour remplacer le câble trop court du casque HIFIMAN EDITION XS. Un grand gain en qualité également par rapport au câble d'origine. (Il faut quand même qu'on m'explique la signification de symétrique pour un câble casque. Les normes étant bien faites, le + et le - se retrouvent quand même au bon endroit à droite et à gauche.)
David S.
HIFIMAN EDITION XS Casque Planar Magnetic 92dB 18 Ohm 8Hz-50kHz HiFiMan propose avec son casque Edition XS un excellent modèle Planar Magnetic, utilisant les technologies propriétaires Stealth Magnets et NEO Supernano Diaphgram...
rien à redire
OK pour le prix, c'est surement difficile de trouver mieux.
Casque pas tout à fait neutre à mon avis, mais tous les détails sont là et très bien pour une écoute au casque occasionnelle, car il est un peu lourd. Câble de qualité moyenne et ridiculement court pour mes besoins (95 cm jusqu'à la séparation des câbles) qui gagne à être remplacé par un plus long et plus qualitatif. Bizarrement il passe mieux sur un ampli casque à base de 6922 équipé avec des 6N23P-EV que sur mon HA-B6120.
Thibaut M.
Top - Résultat très satisfaisant
Installé sur PI 4 B et alimentation IFI AUDIO IPOWER MK2 pour l'ensemble, je stream du Hight Res sur Qobuz avec Moode. Le résultat est très bon sur un ampli atoll et enceintes B&W, très large scène sonore, détails impressionnants pour le prix. A moins de 250€ l'ensemble, on concurrence des lecteurs réseaux 2 à 3 fois le prix sans problème. Bravo audiophonic pour ce matériel.
Martin B.
TOPPING A50 III Amplificateur Casque Argent Avec son amplificateur casque A50 III Topping dévoile un appareil compact et performant. Ce dernier reprend les caractéristiques de son prédécesseur...
Very nice and "powerful"
Driving a pair of Dan Clark Noire XO with these via the balanced output. These are 13-ish Ohm planar magnetic headphones, so they draw quite a bit of power.
Thought I'd have to buy some expensive headphone amps to drive these, but the A50 III has no issues driving them. The amplifier gets a bit warm at best over long periods of listening with these.
Product also feels nice, it's a sleek slab of aluminum. Quite pretty actually.
And the volume knob is spaced nicely far apart from the headphone jacks so your fingers don't "collide" with the jacks (something many other amps get wrong).
Martin B.
Câble Jack 6.35mm Mâle vers Jack 6.35mm Mâle Stéréo Blindé Plaqué Or 0.5m Ce câble double Jack 6.35mm stéréo propose un cœur en cuivre pur pour une conductivité maximale. Ce dernier est blindé par une feuille en...
Working as advertized
Got two of these (L+R to connect audio interface to headphone amplifiers via balanced connection). Stuffed it into a place with some power cables. As expected, no interference noticeable.
Jérôme K.
AUDIOPHONICS MPA-S250NCX XLR Amplificateur de Puissance Class D Stéréo Ncore NCx252MP 2x250W 4 Ohm Le Audiophonics MPA-S250NCX XLR est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NCx252MP. Cette solution est idéale pour...
Amplificateur xlr bien construit, chauffe légèrement.
Qualité sonore :
Timbre réaliste
Courbe de fréquence droite
Très dynamique
Images stéréo holographique
Grave profond et tendu
Rapidie , très bon sur les transitions, c’est pas un bourrin il c’est être nuancé il a de la matière.
Subjectif ont dirait un mix entre un nad pour le grave et atoll médium aiguës.
Comparer à un classe ab intégré :
Je parle de mes amplificateurs
Nad c3050, yamaha as2100,musical fidility m3si.roksan attessa.
Se sont d’excellents amplificateurs pour alimenter des petites colonnes ou enceintes étagères, pour des belles colonnes 2voie ou 3 voies
Il bat mes autres amplifications en écoute normal plus de dynamique grave mieux tenue meilleure transition grâce a sa grande puissance, mais pour moins 500€ franchement je regrette d’avoir acheté autant de classe ab pour rien j’étais jamais satisfait il manquait toujours quelques chose.
Niveau enceinte :
sonus faber sonetto 8g2, dynaudio evok 50 , et large bande altec 420. Source teac nt 503 .
Peter S.
AUDIOPHONICS STEALTH XLR Câble de Modulation XLR-XLR Cuivre OCC Plaqué Or 0.75m (La paire) La gamme Audiophonics Stealth propose une sélection de câbles particulièrement performants et accessibles, assemblés à la main dans nos...
Inspires confidence
I needed shorter XLR cables, and wanted something of excellent quality without breaking the bank. These cables replaced some cables that cost me some 500 € several years ago. To be honest, life is too short to worry about any minor difference, and this pair do the job perfectly well.
Peter S.
ATAUDIO L-4E6S Câble USB-A Mâle vers USB-B Mâle Cuivre OFC Plaqué Or 0.75m Ce câble USB ATAUDIO offre à la fois une très belle qualité de conception et un design luxueux. Il se compose en effet d'une structure à quatre...
A USB cable, what else ?
So hard to describe what this may or may not bring to the sound of a hifi system. I couldn't say, let's say it doesn't do any harm, and that's a good thing.
Very reasonable price, for a beautifully presented product.
Thomas H.
THINKYA DVR108 Lecteur CD DAC ES9038Q2M Bluetooth 5.1 32bit 768kHz DSD512 Le DRV108 de Thinkya est un lecteur CD et DAC à la connectique étendue, reposant sur un processeur TMC688 et une puce DAC ES9038Q2M. Cette combinaison lui permet...
It is a great product for a small price.
Frank j.
AUDIOPHONICS DIGIRESCUE Module Reclocker SPDIF Optique Coaxial Isolation Galvanique 24bit 192kHz Ce module reclocker Audiophonics DIGIRescue a été conçu en association avec Ian Canada. Il permet, grâce à une horloge locale de haute...
reclocker
reclocker toslink optical
gives 10% better sound
its ok product
Pascal J.
Très très bonne alimentation
Associée à un trafo toroïdal en cuve Talema 80va elle alimente Mon Keces Ebravo.
C'est parfait et procure une
amélioration évidente comparée à celle d'origine ou même une brique Meanwell qualité médical.
Pascal J.
KECES EBRAVO Lecteur Réseau WiFi UPnP DLNA Bluetooth 24bit 192kHz Avec le Elbravo, Keces Audio propose un lecteur réseau compatible avec de nombreux services de streaming et que Spotify, Tidal ou Qobuz ainsi que les protocoles...
Aucun avis ????
Une brique noire avec un œil bleu qui n'a l'air de rien,
sans prétention, un peu chère comparée à la surenchère de bien d'autres. Mais quelle brique !! 1) installation très facile, appli 4stream parfaite, aucun problème. Pas de bidouille, un nas Sinology pour la musitèque.
2) raccordé à mon Sonifex adda2 le son qui me convient de vrais et bonnes
basses, les médiums et aigues en bonne équilibre
avec les précédentes, très bien timbré, un son analogique. Le peu de tests
accessibles sur le net ne vous mentent pas c'est de la balle.
3) à l'intérieur pas grand chose : pas fpga de la mort,
pas d'horloge venue de l'espace. Juste la bonne pièce au bon endroit et beaucoup d'intelligence.
Bravo aux concepteurs
m
Mattias B.
ASCILAB F6B Enceintes Bibliothèque 125W 4 Ohm 84dB Noir (La paire) Les AsciLab F6B sont des enceintes passives de type bibliothèque, offrant une restitution sonore précise et puissante dans un format compact. Ces enceintes 2 voies...
Absolutely amazing
Mattias B.
3E AUDIO A5 Amplificateur Class D Stéréo PBTL 2xTPA3251 2x150W 4 ohm 3E Audio, acteur reconnu dans le monde du DIY, propose le A5, un amplificateur classe D stéréo conçu avec des composants Hi-Fi audiophiles. En effet,...
Outstanding value
Henri c.
JANTZEN AUDIO AIR CORE WIRE COIL 000-0121 Bobine Cuivre 4N 13AWG 1.3mH 0.23 Ohm Les bobines à air Jantzen Audio Air Core Wire Coil sont constituées de fil de cuivre haute pureté, parfaitement bobiné pour créer un inducteur...
bonne tenue du grave
j'ai utilisé cette self pour filtrer un large bande fostex ,( utilisé en quart d'onde ) le résultat est très bon ,avec du 6dB:octave ,ça permet des
bon transitoires, un medium bien présent et un grave bien tenu .
( il faut ajouter un tweeter pour avoir le haut du spectre )
Christian H.
Cable numérique 75 ohms
Pour rerlier les équipement SPDIF coax entre eux dans le respect des normes tels que prévus par les ingénieurs, à un prix raisonnable.
Christian H.
AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Optique Coaxial Isolation Galvanique 24bit 192kHz Ce reclocker Audiophonics DIGIRescue a été conçu en association avec Ian Canada. Il permet, grâce à une horloge locale de haute...
DIGIRESCUE Reclocker Isolation Galvanique de haute volée
1èrement : fait super bien ce pourquoi il est fait.
je ne rentrerai pas dans des chiffres (je n'ai pas en l'état les outils pour) mais parlerai du contexte et du ressentit (à l'écoute).
Sources reliées :
Un tuner DAB synpathique (Sangean WFT-4) cependant avec une sortie SPDIF pas au top.
Une TV avec sortie optique classique.
DAC en reception : TOPPING DX7 PRO upgradé Sparkos labs.
Alimentation du Digirescue : Ifi Ipower X
Résultats Immédiatement perceptibles : précision, profondeur, respect timing, impact, image tridimentionnelle, silence entre les notes, présence indéniable.
Bref hautrement reccommandé pour mettre à niveau des sources SPDIF moyennes avec en plus le bonus isolation galvanique entre appareils respecté (un vrai plus quand on pousse l'optimisation).
Merci Audiophonics pour ce beau et bon produit crée en partenariat avec IAN Canada
Walter M.
WONDOM KAB9 Module Amplificateur PBTL USB 8x50W 4 Ohm Ce module Wondom AA-KA32473 est un amplificateur se voulant particulièrement polyvalent, pouvant être utilisé dans le cadre d'applications très...
perfect for building a multiroom system using LMS/Squeezelite or Homeassistant
Philippe w.
FOSI AUDIO TB10D Amplificateur Class D TPA3255 2x230W 4 Ohm Le Fosi Audio TB10D est un amplificateur Class D compact et puissant, proposé à prix contenu. Son étage d'amplification utilise une puce TI TPA3255 hautes...
étonnant pour le prix . Si votre budget est serré , n'hésitez pas .Il réussit à bouger mes dynaudio émit M20 . Au cas ou , possibilité d'en augmenter la puissance en achetant l'alim 48v .Petit , se pose partout , si une seule entrée ne pose pas de problème (les autres sont sur mon Dac ) . Vraiment difficile de lui reprocher quelque chose . Cool ,bon achat .
André G.
NEUTRIK NL2FXX-W-S Connecteur Speakon Femelle Ø12mm Le Neutrik NL2FXX-W-S est un connecteur Speakon à 2 broches robuste, idéal pour la conception de câbles de qualité professionnelle. Celui-ci...
Belle prise Neutrik
Ce produit Neutrik de qualité certes est un peu compliqué à monter si nous ne possédons pas une clé spécifique Torx ce qui est mon cas, donc impossible à installer. C’est dommage qu un fabricant sérieux comme Neutrik n ait pas prévu d en joindre une dans son package
Par ailleurs le diamètre du câble ne peut excéder 3/4 mm
En conclusion produit de qualité
Stéphane B.
VIBORG VS702 Fourches Cuivre Pur Ø4.5mm (Set x4) Les Viborg VS702 sont des fourches de grande qualité, assurant une connexion et une conductivité optimales. En effet, ces modèles sont conçus en...
Je n'ai noté aucune détérioration du son après l'ajout des fourches Viborg. C'est exactement ce que j'en attendais, ce qui en fait donc un très bon connecteur.
Fabrice B.
EVERSOLO AMP-F2 Amplificateur Class D 2x250W 4 Ohm / 1x450W 2 Ohm Le AMP-F2, développé par EverSolo en collaboration avec l'équipe Starke Sound, est un amplificateur Class D basé sur l'intégration de...
Amplificateur de très bonne qualité
Ma première expérience avec un amplificateur de classe D qui ravit mes oreilles. En remplacement d'un amplificateur Marantz NR1200. Toutes la connectique est présente pour se substituer à ce dernier en 2.1.
Stephane A.
LHY AUDIO LPS50VA Alimentation Linéaire Rrégulée Faible Bruit 230V vers 15V 1.5A 50VA Voici une alimentation linéaire régulée et stable pour tout projet DIY audiophile de haute qualité. Tous les raffinements techniques...
Belle decouverte
Je ne soupçonnais pas les améliorations de ce type de device, une vrai decouverte.
Sert a alimenter mon microdac de Laiv.
Que du bonheur, je conseille
Stephane A.
LAIV HARMONY UDAC DAC R2R Symétrique Discret 24bit 768kHz DSD256 Noir Le LAIV Harmony µDAC, petit frère du LAIV Harmony DAC, est également un DAC R2R symétrique discret. Cependant, il dispose d'un form factor ultra...
Une merveille!
Acheté suite aux avis et différentes reviews sur internet,
J'ai mis quelques heures a comprendre la qualité de ce dac car c'est un son tellement naturel avec une scene sonore en arrière plan qu'au premier abord il semble sonner petit et "froid". Mais après quelques heures d'écoute et un niveau sonore plus élevé permettant de noter concrètement la différence avec le dac de l'avance paris a10 ( que je préfère aux doubles dac de l'eversolo a6 au passage), j'ai enfin compris la qualité, le raffinement, la positionnement des instruments dans l'espace et le côté naturel du son.
Un pas dans la haute fidélité je dirai...
J'ai complété mon set up avec une alimentation linéaire de la marque LHY d'après les conseils d'audiophonics, qui au passage m'a très bien orienté car là encore, j'ai gagné en définition et aération dans l'image. (Je m'orientais vers le ddc de laiv mais il m'a plus conseillé une alimentation linéaire, bravo à lui, car il n'incite pas à dépenser plus)
Bref,on aura compris que je suis ravi des produits et des conseils pro et réactifs du conseiller d'audiophonics.
Prochain upgrade, alimentation linéaire pour l'eversolo a6.
Frank G.
Bestes USB Kabel zu diesem Preis
Habe mehrere USB Kabel von namhaften Herstellern ausprobiert.
Das einzige USB Kabel , was tatsächlich besser spielte , war das Audioquest Diamond ( Für mein Budget viel zu teuer)
Das neue Furutech GT 2 NCF spielte auch auf dem Niveau vom Neub 1020 , aber in meiner Kette hatte das 1020er etwas mehr Luft im Hochtonbereich und der Tiefton klang etwas kräftiger.
Jetzt muss aber auch noch dazu schreiben, dass das Neotech schon über mehrere Monate eingespielt war und das Furutech ungefähr 50 Stunden.
Aber auch das Furutech kostet das Doppelte vom Neotech
Jean-Pierre B.
NEOTECH NES-3001G Câble Haut-Parleur Cuivre au Graphène G-UPOCC 8.3mm² Ø15mm Le NES-3001G de Neotech est un câble pour haut-parleur intégrant 16 conducteurs composites G-UPOCC, combinaison de cuivre OCC et de graphène, d’une...
La construction d'un câble pour haut-parleur sur cette base m'a paru un peu compliquée aussi j'ai demandé à l'atelier Workshop d'Audiophonics de le faire pour moi. L'idée était de construire un câble dans l'esprit "Obsidian". Il est ainsi monté notamment avec des fiches bananes Viborg VB404AG et des gaines Viablue noires le tout du plus bel effet. Le résultat est en effet de toute beauté.
Au niveau de l'installation, la recommandation de l'atelier est la suivante "Le câble étant très rigide, n'hésitez pas à lui faire prendre une forme permettant de réduire l'effort sur les connecteurs". Le câble est bien gros et bien lourd et il faut travailler sa forme de façon à ce que la connexion sur les borniers de l'ampli et des enceintes se fasse avec une pression dans le bon sens, ce d'autant que les connecteurs en argent sont relativement fragiles.
Ceci posé, et même si le câble est superbe au plan esthétique, ce n'a pas été une surprise car conforme à mon attente.
Non la surprise vient de l'écoute. Comment dire, et ce avant tout rodage, j'ai obtenu plus de tout : extension dans le grave et dans l'aigu sensible, scène sonore plus profonde et plus large, instruments avec plus de matière etc. et pourtant mes câbles précédents n'étaient pas bas de gamme tant s'en faut (câble ELECAUDIO HP-25OFCS et fiches ETI KRYO). Le plus étonnant est que la qualité du fichier joué se ressent immédiatement en particulier avec une source en 24 bits au lieu de 16.
En conclusion, un câble exceptionnel avec un prix à l'avenant mais aucun regret, bien au contraire.
Au passage une sixième étoile pour l'atelier Audiophonics pour sa compréhension instantanée de la demande, ses bons conseils et sa rapidité d'exécution (environ 2 jours ouvrables entre la confirmation de commande et l'expédition) et aussi pour la qualité du montage qui est tout simplement parfaite.
Jurie J.
IAN CANADA TRANSPORTPI DIGI II Module Interface Audio Numérique Ultra Faible Jitter Avec le TransportPi Digi II, Ian Canada nous propose une belle évolution de leur interface audio numérique tout-en-un haute performance pour Raspberry Pi. Ce...
Super Saund.
Connecteur de grande qualité, facile a souder, mécanique irréprochable et transmission pour un câble d' horloge parfaite.
Sylvain S.
AUDIOPHONICS HPA-DM750ET Amplificateur de Puissance Double Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm Le Audiophonics HPA-DM750ET est un amplificateur de puissance Class D profitant d'une architecture double mono. Celle-ci intègre deux modules d'amplification Purifi...
Le début d'une nouvelle ère de haute fidélité
Du dynamisme, de la puissance et de la précision. Ce produit a révélé tout ce qui ne restituait pas correctement la musique sur l'installation.
L'ensemble des sources et DAC ont été changés pour lui permettre de s'exprimer à sa juste valeur.
Un produit incroyable à utiliser sur la connectique XLR.
Merci à Audiophonics de permettre à ces produits d'exception d'exister.
Sylvain S.
SINGXER SDA-6 PRO2 DAC Symétrique 2x AK4499EX AK4118 FPGA XMOS I2S LVDS 32bit 768kHz DSD512 Le SDA-6 PRO2 de Singxer, seconde version du SDA-6 PRO, est un DAC symétrique haute fidélité. Il présente de nombreuses améliorations par...
Un DAC pour (re)décrouvrir le son numérique
C'est en voulant changer de produit qu'on se rencontre de la valeur qualitative de ce produit.
Il est équipé de la fameuse puce de conversion AK4499EX qui apporte le son VELVET SOUND synonyme de précision et de douceur.
Il est aussi équipé d'un contrôle de volume numérique, parfaitement exempt de tous bruits parasites, permettant de le brancher directement sur un amplificateur de puissance. Le silence est remarquable.
Merci à Audiophonics de proposer des produits innovants et de cette qualité.
Sylvain S.
DENAFRIPS HERMES 12TH Interface Digitale DDC USB I2S SPDIF Optique Toslink AES 32bit 384kHz DSD512 Noir Le convertisseur numérique-numérique ou interface digitale (DDC) USB Hermes 12Th de Denafrips est le fruit de 3 ans de recherche et développement par la...
Le chef d'orchestre
Ce convertisseur numérique vers numérique apporte stabilité et lisibilité dans le message sonore. Tout devient précis et juste au bon moment. Un maillon indispensable dans toute installation utilisant un lecteur réseau audio.
Peter H.
Filtre USB 5V à Supercondensateurs USB-C vers USB-C / USB-A Ce filtre USB 5V vous permet d'obtenir une alimentation propre de vos appareils Hi-Fi grâce à deux condensateurs 20F - 3.0V ainsi qu'un...
Noticeably improved the sound in my system
I'm using this filter with an iFi SPDIF iPurifier2, which gets its power from a computer USB port. It's reclocking the Toslink signal coming from a Samsung TV. I'm also using an Audiophonics Digirescue after the iFi unit to reclock the signal one more time. The Digirescue is powered by an iFi Elite. Using both of these units in this specific order, with iFi first and Digirescure second, makes the sound by far the best in my system. I've tried every other combination of using no reclocker, only one reclocker powered by iFi Elite, and the two at the same time. Using both sounds best, and by adding this Supercapacitor filter for the iFi and its dirty PC power source made the sound leap to the next level.
I also have a USB source, and before I added this Supercapacitor filter the SPDIF source was a bit worse than my USB source. But with this filter in place the SPDIF signal is now better than USB by a comfortable margin. These supercapacitor filter products are probably the most cost effective method of removing power noise. In my system it exceeded expectations. Highly recommended!
Serge B.
SMSL DO100 PRO DAC Symétrique 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA Le DAC symétrique SMSL DO100 PRO est une évolution du DO100 proposé par la marque. Le DO100 PRO bénéficie de nombreuses améliorations....
Bon rapport qualité/prix
Ne recherchant pas l'excellence à tout prix, mon oreille, d'ailleurs, ne me le permet pas puisqu'elle n'identifie pas les différences entre les formats MP3, FLAC et HiRes, ce petit DAC a une conversion et une restitution sonore qui me conviennent.
J'utilise les entrées optique (tv via le player de ma box) et coaxiale (lecteur réseau) et la sortie RCA (ampli intégré9.
La télécommande, qui fonctionne avec 2 piles R03 non fournies, s'apprivoise vite à condition de consacrer 2 minutes à lire la notice d'utilisation (en anglais)
luca f.
Articolo di scarsa qualità
Dopo 4 anni di utilizzo le prese si distaccano dall' interno,così è successo a me e ad altri amici, prodotto veramente di scarsa qualità
GEORGIOS C.
ELECAUDIO ADIACIUM GR Gaine Tressée Extensible Nylon (PET) 4-11mm Gaine tressée élaborée en  PET (Polyéthylène Terephtalate)  monobrins pouvant être utilisée dans une large...
The ADIACIUM series are great products
All of the products in the ADIACIUM series from ELECAUDIO are excellent. They have a very dense weave, they stand the test of time and also - very importantly - when handled carefully, they do not melt from the temperature of the air gun (on the low setting), used for the heat shrink tubing that will seal the ends (or elsewhere on our project).
Vladimir V.
LUDIC AESIR Câble secteur Schuko IEC C15 Cuivre UP-OCC plaqué Or 2m Le Ludic Aesir est un câble d'alimentation de grande qualité. Il intègre en effet des conducteurs en Cuivre UP-OCC Drawn® brevetés, permettant...
Best value for the money
This is one of the best cables in the market. It doesn't do anything to the sound, just let your equipment work at its best.
Despite the thickness, it is flexible enough.
Ioannis P.
OYAIDE TUNAMI TERZO RR Câble de Modulation RCA 0.7m (La paire) Ce câble modulation de très haute qualité est assemblé avec des connecteurs Focus 1 des plus réputés et un câble 102SSC,...
Absolute pleasure
Used between vintage control pre and power amp (Kenwood Basic C2 and Technics SE-A5). Tremendous imaging, super wide and balanced soundstage, revealed supreme performance, accuracy and tonal clarity with a neat warm scent. Oyaide at its best, a real performer.
Ioannis P.
Great VFM
Nice solution for digital sources. Really decent soundstage and imaging, will trim / roll-off harsh treble frequencies on such equipment.
Ioannis P.
Fiches Bananes Plaqué Rhodium Ø7mm (La paire) Ces fiches bananes, bien que peu onéreuses, profitent d'une belle qualité de conception. Les lamelles de ces fiches permettent un très bon contact entre le...
Top quality
Very nice fitting, excellent value for money. Combined with Supra Classic 4.0 on second system.
A C.
SPARKOS SS 3602
Tout d' abord envoi reçu en 48 h00 et bien emballé pour un prix compétitif. Installation sur un fosi bt20apro sans problèmes. Dés la première écoute amélioration très nette par rapport aux op d' origine. Son plus profond et chaleureux, certains détails ressortent mieux, le tout contribuant à une écoute moins fatigante sachant qu' une période de rodage ne pourra qu' améliorer ce premier constat
A H.
NEOTECH NEI-3004G Câble de Modulation Symétrique Cuivre G-UPOCC Graphène Ø8.5mm Le câble de modulation NEI-3004G de Neotech est un câble de modulation symétrique incorporant 2 conducteurs composites G-UPOCC, combinaison de cuivre OCC et...
Very nice cable
The sound is neutral, clear and very open. With this level of transparency this definitely is a bargain. Thanks to Audiophonics and the reviewers to bring the attention to this cable.
It has arrows for the direction, but they are hard to see. I think it is just a handy feature to find back the side where you put the shield to the ground. I didn’t read anything about directionality. I build them the wrong way but these cables sound so good that I cannot believe I made a mistake to make them the other way around.
A H.
VIBORG VF518R Connecteur IEC C7 Cuivre pur Plaqué Argent / Rhodium Ø20mm Le connecteur d'alimentation IEC C7 Viborg VF518R offre une très belle qualité de fabrication, assurant transmission extrêmement fiable du signal...
Viborg quality control should be better
The VF518 should have a metal body, like in the picture shown. It looks like Viborg puts VF508 plugs in a box that says VF518. Hence the Audiophonics description that says it has a nylon body. But I believe that is due to Viborg putting the wrong plugs in the boxes.
The plastic body is nice though, so I will keep it.
Don’t expect Furutech-type bolts, the Viborgs bolts/ screws are smaller and weaker. But Viborg plugs are also cheaper.
Only 2 stars because of the bad quality control of Viborg, although I am still satisfied with the plug.
stephane e.
Qui peut mieux?
Aussitot commandé,presque aussitot livré!
Ce petit bijou est destiné a driver des jmr orféo grande accompagné de l'eversolo dmp-10. Etant habitué au classe D de mon appareil actuel je recherchais plus de controle des basses,plus séche plus percutante quoi!
C'est chose faite,la puissance aidant cette ampli délivre sur tous les registres un son limpide ,aéré avec de la profondeur,de la largeur tous est bien distillé entre les enceintes.
Meme a bas volume,la dynamique ne s'écroule pas et les détails sont la.
Bravo a toute l'équipe pour avoir osé créer une machine qui délivre une puissance colossal et qui laisse passer la musique émotionnellement tel qu'elle est!
DAVID P.
VRAIMENT BIEN
Les polémiques et discussions sur les cables vont bon train sur les forums et ne sont pas toujours rationnelles ou seulement objectives. pour ma part je pense que l'on devrait batir son systeme avec des cables neutres comme les Cordial ou les Canare, puis une fois celui ci stabilisé, on peut commencer a investir dans des cables plus haut de gamme (que ce soit de modulation ou d'enceinte). J'utilise depuis plusieurs mois les Oyaide Across 3000 qui sont chatoyant. J'avais besoin de 2x2.5 metres pour mon Mc275 et ne voulais pas dépenser 250 € j'ai donc opté pour ces Oyaide deux fois moins chers. La différence est immédiatement perceptible. Pour l'instant les aigus sont peut etre un peu moins moelleux qu'avec les Across mais les basses sont terrifiques. Si votre systeme est un peu juste dans ce domaine, vous pouvez essayer les Explorer, vous devriez obtenir une amélioration notable.
