Jean-louis L.
Jean Michel P.
Hervé R.
Pas si bien que ça !
List of products LHY Audio
LHY Audio designs and distributes high-performance and affordable DIY audio modules. The brand offers a wide range of products, from digital interfaces to linear power supplies, Bluetooth receivers and clocks.
  • Ref : 19755
    This LHY Audio Receiver interface module converts an HDMI LVDS signal into an I2S signal. It accepts PCM and DSD signals, enabling users to enjoy high-resolution files.
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 17565
    In Stock
    The single AOP LHY AUDIO is a discrete class A operational amplifier. Mounted on a stand, it offers quick assembly thanks to its DIP8 format. Even once installed, the AOP is easily changed. Designed for professional audio applications, it offers great performance. Indeed, it has greatly reduced noise, distortion and achieved an output current of 65mA.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 17570
    In Stock
    The double AOP LHY AUDIO is a discrete class A operational amplifier. Mounted on a stand, it offers quick assembly thanks to its DIP8 format. Even once installed, the AOP is easily changed. Designed for professional audio applications, it offers great performance. Indeed, it has greatly reduced noise, distortion and achieved an output current of 65mA.
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 19756
    This LHY Audio Send interface module converts an I2S signal to HDMI LVDS. It accepts PCM and DSD signals, enabling users to enjoy high-resolution files.
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 19168
    LHY Audio offers us their SW-10 network switch. This switch features 8 RJ45 Ethernet ports, 2 SFP fiber optic ports and an input and output connected to the 10mHz OCXO clock. All of this is housed in an elegant anodized aluminum case, machined from solid, and designed to separate AC power processing, DC power processing and audio signal processing.
    1 890,00 € 1 575,00 €Ex.
    In Stock
  • Ref : 19170
    In Stock
  • Ref : 19488
    In Stock
    With the SW-6 SPF, LHY Audio offers us a network switch featuring 5 RJ45 ports, one of which is digitally isolated, a fibre optic SFP port and a BNC input connected to the 10mHz OCXO clock. All this is housed in an elegant anodised aluminium enclosure machined from solid material and designed to separate AC current processing, DC current...
    859,00 € 715,83 €Ex.
    In Stock
  • Ref : 19490
    In Stock
    In Stock
  • Ref : 19491
    In Stock
    In Stock
  • Ref : 17281
    In Stock
    This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal. The module can be AC or DC powered and is capable of delivering 5V and/or +/-12V (adjustable over a range of 1.2V to 20V). It can be used to provide three positive outputs or one...
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 17279
    In Stock
    This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal. The module can be AC or DC powered and is capable of delivering 5V and/or +/-5V (adjustable over a range of 1.2V to 20V). It can be used to provide three positive outputs or one...
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 18475
    In Stock
    This LHY Audio UBT-1 digital interface lets you transmit a high-quality digital audio signal via your computer, tablet or smartphone to other digital audio devices. The UBT-1 digital interface features a USB-B connector input, a Bluetooth 5.1 receiver chip and several outputs: AES/EBU, SPDIF Coaxial, Optical Toslink, and HDMI-I2S.
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 18765
    In Stock
    With its UIP, LHY Audio unveils a high-performance 480Mbps USB 2.0 isolator incorporating an internal OCXO + PLL clock system for perfect transmission of your sound signal via USB connectors. The LHY Audio UIP works plug and play thanks to a USB-B input and a USB-A output supporting the USB 2.0 protocol. USB...
    549,00 € 457,50 €Ex.
    In Stock
  • Ref : 19741
    In Stock
    The LHY FMC galvanic network isolator optimizes your audio system's Ethernet LAN connection. It converts the network signal into an optical signal via its SFP port, and outputs it via its galvanically isolated RJ45 port.
    569,00 € 474,17 €Ex.
    In Stock
  • Ref : 19746
    In Stock
    589,00 € 490,83 €Ex.
    In Stock
