Material
Diameter (mm)
Height
mm
mm
Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound...
Pierre-Marin L.
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba...
Aluminium feet
Aluminum shock & vibration and Spikes to deal with unwanted vibrations and avoid picking up avoidable noise in your High Fidelity audio devices. Stackable supports and discreet pieces according to your needs and the general aesthetics of your installation.
