Amplifier Module Stereo Class D Infineon MA5332
This Class D stereo amplifier module is based on an Infineon MA5332 amplifier chip. It can deliver 2x125W at 4 Ohm, or 2x65W at 8 Ohm. For signal input, the module accepts an single-ended stereo RCA input, via two 2-pin PCB connectors.
Reference : 18841
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 13-08-2025.
Amplifier Module Stereo Class D Infineon MA5332 2x125W / 4 Ohm
Amplifier Module Stereo Class D Infineon MA5332 2x125W / 4 Ohm: front view
This Class D stereo amplifier module is based on an Infineon MA5332 amplifier chip. It can deliver 2x125W at 4 Ohm, or 2x65W at 8 Ohm. A heatsink is fitted to the MA5332 chip for efficient heat dissipation. For signal input, the module accepts an single-ended stereo RCA input, via two 2-pin PCB connectors. The module's power supply accepts a range from 200 to 240V AC. Furthermore, this Class D amplifier module can be used to power other modules, such as a DAC, thanks to several power supply outputs: respectively a -/+ 12V 300MA output, a +38V 200MA output, and a +5V 1A output.
Amplifier Module Stereo Class D Infineon MA5332 2x125W / 4 Ohm: power outputs
Product typeClass D stereo amplifier module
Amplification chipInfineon MA5332MS
Input1x Single-ended RCA stereo input on PCB connector
Ouputs2x125W @ 4Ω, 0.1% THD+N
2x65W @ 8Ω, 0.1% THD+N
Additional connectors+/-12V 300MA power supply output
+38V 200MA power supply output
+5V 1A power supply output
Signal-to-noise ratio (SNR)90 dB
Power supply200V - 240V AC
Dimensions250 x 80 x 40 mm
Mounting holes245 x 65 mm
Weight515g
Package1x MA5332 class D stereo amplifier module
InputPCB Connector
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA5332M
Power (W)125.0
Amplifier Module Stereo Class D Infineon MA5332 2x125W 4 Ohm
This Class D stereo amplifier module is based on an Infineon MA5332 amplifier chip. It can deliver 2x125W at 4 Ohm, or 2x65W at 8 Ohm. For signal...
