No featrued products
Stereo Class D TPA3250 2x100W 4Ω
This Class D stereo amplifier module is equipped with a TPA3250 chip allowing it to deliver 2x100W of power at 4Ω, and this with high efficiency. A chip that also takes advantage of the PurePath™ Ultra-HD architecture, ensuring a very low level of distortion over the entire frequency range for a precise, detailed and clear sound reproduction. The input to the module is in analog on XH2.54mm connector and the output on screw terminals.
| Specifications | |
| Product type | Amplifier |
| Amplification type | Class D |
| Channels | Stereo (2) |
| Amplification chip | TPA3250 |
| Output power | 2*100W @ 4Ω, 32V, 1% THD+N 2*60W @ 8Ω, 32V, 1% THD+N |
| Efficiency | 90% |
| Static current | 50mA |
| Frequency response | 20Hz - 20kHz |
| Max output current | 4A |
| General | |
| Supply voltage | 18-32VDC (power supply sold separately) |
| Dimensions | 103*78*15mm |
| Mounting holes spacing | 96*71mm |
| Weight | 80g |
| Input | PCB Connector |
| Output | Speaker terminal |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3250 |
| Power (W) | 100.0 |
