XMOS interface digitale USB 24/192khz Alimentation 230V Black
XMOS interface digitale USB 24/192khz Alimentation linéaire Black
10547
169,00 €tax incl.
140,83 € tax excl.
Available
Shipping date: 23-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
This interface based on the now famous XMOS makes it possible to have digital outputs of high level in S / PDIFcoaxial, optical,AES / EBU and I2S. The USB has an Asynchronous management of the USB.
This version offers an interfaceXMOS combined with an integrated regulated linear power supply. Recognized without drivers under MacOS and linux this requires a Windows Driverhttp://www.audiophonics.com/images2/8658/XMOS-Stereo-USB-Audio-Class2-Driver-2013(v2.19.0).zip "target =" _ blank ">(Click here)
This model has a regulated linear supply as standard and can be directly connected to the 220V.
This digital interface is compatible with devicesAudio-GDwith an RJ45 I2S or AES / EBU input.
Features:/ Strong>
  • Case 100% Brushed Aluminum
  • Black facade
  • Compatible with Raspyfi, Volumio, Picoreplayer
  • Clock: 24.57MHz, 22.57MHz TCXO
  • 1 Clock 12Mhz
  • Jitter: 4.6 ps
  • Regulated power supply low noise
Digital Outputs:
  • Coaxial 75 ohm: 24 bit 44.1Khz ~ 192khz
  • AES / EBU 110 Ohm: 24 bit 44.1KHz ~ 192kHz
  • Optical toslink: 24 bit 44.1khz ~ 192Khz
  • I2S RJ45:32 bit 384Khzon RJ45 connector
Dimensions and poids:
  • Dimensions: 162x114x47mm
  • Weight: 0.9kg
  • USB and mains cables not included
Wiring diagram of output I2SconnectorRJ 45:
  • Pin 1 DATA DSD A.
  • Pin 3 I2S LRCK dsd CLK.
  • Pin 5 I2S SCLK DSD B.
  • Pin 7 I2S MCLK.
  • Pin 6 and 8 GND MCLK.
  • Pin 2 and 4 GND.
I2S R45 Xmos 32 bit 384Khz
Colissimo - TNT - SoColissimo
2 reviews
ok
Je l'utilise avec un DAC Audio GD qui a déjà quelques années (fin 2011 - NFB 2 je crois), à la place de la puce USB intégrée au DAC (tenor 7022 - USB synchrone, pas mal à l'époque mais qu'on ne trouve plus à ce niveau de gamme). Ca tient ses promesses : c'est plus transparent, plus présent, même à faible volume. Avec l'alimentation interne, l'utilisation sur un Rasp Pi ne pose aucun souci. Donc l'objet n'est certes pas donné, mais va me permettre de faire durer mon dac préféré !
 (4)
This review has been posted for XMOS interface digitale USB 24/192khz Alimentation 230V Black
A quand la simplicitée
comme il faut téléchargé 1 truke donc il ne marche pas j'attend le filston, car l'informatique et moi ça fait 2, quelll bazard. pour l'instant il dorrr, a quand du matos simple a installé
Bonjour,
oui en effet, un pilote est nécessaire pour ce périphérique comme pour la plupart des accessoires USB modernes.
Il existe des DAC et interfaces dont les pilotes sont inclus dans Windows mais ce sont tous des appareils anciens.
