Audio-Technica ATH-WP900
These ATH-WP900 headphones from Audio-Technica are closed dynamic circum-aural headphones featuring two Ø53mm transducers. Its curly maple shells, made by Japanese guitar maker Fujigen, guarantee clear, natural sound quality and high-end aesthetics.
By buying this product you get 64 loyalty points
Reference : 18518
649,00 €tax incl.
540,83 € tax excl.
AUDIO-TECHNICA ATH-WP900 High Fidelity Closed Dynamic Headphones 1000mW 38 Ohm 100dB 5Hz-50kHz
AUDIO-TECHNICA ATH-WP900 Casque Dynamique Fermé Haute Fidélité
These ATH-WP900 headphones from Audio-Technica are closed-back dynamic circum-aural audio headphones featuring two Ø53mm transducers. Its curly maple shells, made by Japanese guitar maker Fujigen, guarantee clear, natural sound quality and high-end aesthetics. These headphones feature a very wide frequency response thanks to their structure and a power handling level of 1000mW. Its 38 Ohm impedance and connectivity make it compatible with most Hi-Fi equipment.
Audio-Technica ATH-WP900: a high-end structure
The exclusive Ø53mm transducers feature a powerful magnetic circuit, amorphous carbon (DLC, Diamond-like carbon) coating and overhanging circuit boards for exceptional full-band frequency reproduction. To improve air circulation between the front and rear of the diaphragm, Audio-Technica has incorporated an inclined baffle to accentuate midrange and bass.
Zoom sur la coque du AUDIO-TECHNICA ATH-WP900
AUDIO-TECHNICA ATH-WP900 : connectique A2DC
Audio-Technica ATH-WP900: Proprietary high-performance connectors
The ATH-WP900 high-fidelity headset uses A2DC (Audio Designed Detachable Coaxial) connectors. This solution has been developed to offer a perfect balance between safety and ease of use, and to reduce unwanted connector rotation that can cause noise or signal interruptions.
Audio technica ATH-WP900: comfortable headphones with impeccable aesthetics
The curly maple shell finish brings out the unique grain of each headset. In addition, the ear cushions and headband are covered in soft synthetic leather for long-lasting listening comfort. The headphones' swivel design makes them easy to carry.
Vue du casque AUDIO-TECHNICA ATH-WP900 plié
Les accéssoires du casque AUDIO-TECHNICA ATH-WP900
Audio technica ATH-WP900: essential accessories
The ATH-WP900 comes with two detachable 3m cables with A2DC connectors. One has a gold-plated 3.5mm jack connector, so the headphones can be used with a wide range of devices. The other has a symmetrical gold-plated 4.4mm jack connector, also for use with Hi-Fi equipment and high-quality sound reproduction.
Product typeHigh-fidelity audio headphones
Transducer typeDynamic closed
Transducer diameterØ53mm
Frequency response5Hz -50kHz
Max. permissible input power1000mW
Sensitivity100dB/mW
Impedance38 Ohm
ConnectorsA2DC
Net weight243g
Package1x Audio-Technica ATH-WP900 headphones
1x A2DC to 3.5mm jack cable
1x A2DC to 4.4mm balanced jack cable
1x Carrying pouch
ColorWood
Impedance (Ω)38
Efficiency / Sensitivity (dB)100.0
Lowest frequency (Hz)5
Highest frequency (Hz)50000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorA2DC
These ATH-WP900 headphones from Audio-Technica are closed dynamic circum-aural headphones featuring two...
