This Audiophonics RJ45 Cat 8.1 STP Ethernet cable, hand-assembled in our workshops in France, incorporates top-quality components to deliver excellent transmission performance. It uses Sommercable Mercator Cat 8.1 cable, with 8 OFC copper conductors of 0.32mm² each. The conductors are twisted and double-shielded with tinned copper braid. The cable is terminated on both sides with Telegartner MFP8 Cat 8.1 T568B RJ45 connectors with gold-plated contacts and zinc-molded shielding. Finally, the cable is covered with a red, black and gray braided sheath from Viablue.
Thanks to its meticulous design, this Audiophonics RJ45 Ethernet cable reaches Cat 8.1, enabling very high transmission speeds of up to 40Gbps.
Product type | Ethernet RJ45 cable |
Length | 3m |
Category | Cat 8.1 |
Bandwidth | Up to 40Gbit/s |
Transmission frequency | 20000MHz |
Technologies | PoE / PoE + / VoIP |
Cable impedance | 110Ω |
Cable conductors material | OFC copper |
Cable conductors section | 8x0.32mm² (22AWG) |
Connectors contacts plating | Gold |
Connectors body material | Cast zinc |
Color | Black, red and gray |
Length (m) | 3.0 |
Shielding | Yes |
Section (mm²) | 0.32 |
Connector | RJ45 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
