NEOTECH NECE-3001 MKIII Litz Cable UP-OCC Copper for Headphone Ø3mm
The Neotech NECE-3001 MKIII is a headset and IEM cable with 4 multi-stranded Litz UP-OCC copper conductors. Each conductor is insulated with a transparent PVC jacket.
4.4 / 5
Reference : 15449
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 03-06-2025.
Câble au mètre
Neotech NECE-3001 MKII Câble Cuivre UP-OCC Litz pour Casque Ø3mm
Litz wire is a conductor with each strand electrically insulated by a polyurethane coating. This reduces the impact of the skin effect, i.e. a current that flows only on the surface of the conductor at high frequencies, as well as the proximity effect that increases resistivity. Such a design is particularly suitable for audio use as it improves the conductivity and limits the resistivity of the cable, resulting in excellent audio reproduction.
To achieve a good solder joint on this type of cable, it is best to remove the coating with a soldering flux.
Product typeHeadphone / IEM cable
Number of conductors4
Conductors materialUP-OCC Copper
Litz wires
Insulation materialPVC
ColorCopper
QuantitySold by the meter
Diameter (mm)3.0
ShieldingNo
Section (mm²)N/A
Ground / ShieldingNo
8 reviews
great price for OCC cable
Bought it to make custom headphone extension cable. Flexible, the PVC is exterior is durable. Price is very reasonable for OCC copper.
This review has been posted for NEOTECH NECE-3001 MKIII Litz Cable UP-OCC Copper for Headphone Ø3mm
Au delà de mes espérances
J’ai endommagé de manière importante le câble d’origine de mon Sennheiser HD800s et le câble de remplacement est très cher.
J’ai commandé un câble chez Furutech mais ils ne sont plus disponibles…
J’ai demandé à Audiophonics de m’en confectionner un et ils ont refusé (c’est pas sympa !). J’ai donc pris mon courage à deux mains et j’ai confectionné moi même le câble de remplacement. Heureusement je suis bien outillé. Je comprends maintenant pourquoi Audiophonics ne veux pas m’en faire un …
C’est une galère ! Surtout au soudage car il faut attaquer à plus de 370• pour que la soudure accroche le fil. (Soudure argent 10%)
De plus les connecteurs de l’embout spécifique au HD800 sont minuscules. Si vous n’avez pas de loupe passez votre chemin.
Le cordon est souple et agréable. Coté Jack j’ai beaucoup moins galéré curieusement. Repérage obligatoire au testeur métrique. C’est pour ça que j’ai commencé par les embouts casque pour finir par le Jack 6,35.
Résultat : exceptionnel. J’ai un gain significatif dans tout les registres . J’ai ce caque depuis plus de 6 ans et je le connais très bien. Et là il dépasse tout. Après rodage la coquetterie dans les hautes fréquences disparaît et le grave est plus ferme. Les voix sont très centrées comme jamais. C’est confondant de naturel. Ampli casque CHORD Hugo2.
 (3)
Nice cable for headphones
Good quality cable but the insulation melts while "soldering" off the litz wire coating. So a little bit tricky to solder but otherwise very good looking and flexible cable.
Très Très bon rapport qualité-prix
Apporte beaucoup de détourage, caractéristique de l'OCC et une très bonne profondeur.
Si votre casque est un peu décharné, par contre, passez votre chemin.
Peu microphonique, mais vous pouvez lui rajouter une gaine textile sans trop la tendre.
Les fils ne sont pas repérés, vous aurez besoin d'un multimètre et d'un fer qui chauffe beaucoup.
Super Câble !!
Mais quel galère à travailler...
Si j'ai bien compris, chaque brins est isolé individuellement et ça doit être vrai puisqu'il est impossible de trouver les extrémités au multimètre.
J'ai du les traiter à l'acide chloridrique pour retrouver de la conductivité.
Vraiment pas pratique ce câble (vendu au mêtre)
Pour le son, à 20€ c'est un sans faute.
Utilisé pour remplacer un câble casque AKG N90Q trop long.
(jack-jack)
La différence est flagrante en sa faveur.
tout est mieux sur tous les critères.
L'image stéréo est ce qui m'a le plus impressionné.
on pousse le volume et rien ne bouge , tout est en place.
Gros surcroit en définitons, tout est plus lisible.
Un comble pour un casque fermé de ce niveau.
il parait qu'un câble casque n'améliore pas tant que ça le résultat final et bien ça va quand meme plus loin.
Vraiment très bon, je recommande à un point que j'ai envie de l'essayer partout juste pour voir...
 (3)
The Neotech NECE-3001 MKIII is a headset and IEM cable with 4 multi-stranded Litz UP-OCC copper conductors. Each conductor is insulated with a...
