Partisan du câble nu, forcé d'utiliser des fiches bananes côté ampli. Après plusieurs essais de différentes fiches, j'ai enfin trouvé celles qui me conviennent. Transparence incroyable. Le top !!!
Silver Plated Pure Copper ⌀ 4mm (Set x8)
KLEI for the creation of its Harmony banana plugs has notably worked on maintaining the integrity of the signal and thus limiting its attenuation to a minimum. Thus, the choice of materials is an essential element, whether it is the structure or the contacts. The body is based on a heat-resistant, electrically inert polymer and has pure copper silver plated contacts.
To optimize the electron flow and define the materials to be used, KLEI uses a mathematical formula that relates signal to earth. The result is greater control, also avoiding the skin effect. This optimization ensures a wider frequency range and harmonics transported without deterioration from one point to another in your system.
To optimize the conductivity of its banana plugs, KLEI chooses the best metals. We can find contacts made of pure copper > 101% IACS silver plated.
These Harmony banana plugs allow easy soldering. In addition, the connector format is also designed to be able to connect two plugs to a single plug, e. g. in the case of two-wiring.
Contacts material | Pure Copper > 101% IACS Pure Silver |
Body material | Heat resistant thermoplastic |
Connection type | Soldering |
maximum acceptable cable diameter | 4mm (6AWG) |
Package content | 4x red banana plug 4x black banana plug |
Max cable diameter (mm) | 4.0 |
Mounting type | To weld |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Vincent M.
Patrick R.
Benoit s.
Patrick B.
