The Tinysine TSA5001 is a compact Bluetooth 5.3 transmitter module with I2S input. It can be used to connect an audio player with an I2S digital output to an amplifier with Bluetooth wireless reception.
This Bluetooth receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this module to stream your music from your smartphone but also to answer incoming calls from your phone.
This Bluetooth 5.0 aptX receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this module to stream your music from your smartphone but also to answer incoming calls from your phone.
This TinySine TSA6178 Bluetooth 5.0 receiver with coaxial SPDIF output will allow you to stream and control your music remotely from your smartphone or connected tablet. The integrated AudioB Digi module supports the aptX transmission codec, for a quality sound reproduction.
This Bluetooth 5.0 receiver module TinySine TSA6178 allows you to broadcast your music remotely, for example from a smartphone or a tablet. The output is in SPDIF coaxial and the module can be connected to your existing audio system. Bluetooth reception is provided by an AudioB Digi module and supports the high-quality aptX transmission codec. The TSA6178...
This Bluetooth 5.0 audio receiver connects to the Line-In or Aux input of your audio system. You can then stream audio from your mobile phone or Bluetooth-enabled audio player to your audio system. Enjoy the convenience of having your music source in the palm of your hand and listening to it on your stereo.
The Wondom BEB1 Bluetooth receiver module, part number AA-AB41163, is a small Bluetooth receiver module featuring a QCC5171 Bluetooth 5.3 receiver chip, an ES9018K2M DAC chip and a USB-C connector input.
This package of Wondom functional cables has been designed for use with the WONDOM AA-JA32175 JAB2+ Bluetooth Amplifier Module. It includes a Bluetooth antenna, a 3.5mm jack line-in cable, a 4-pin to 4-pin speaker cable, a Bluetooth operation indicator LED, a tinned 4-pin speaker cable, a volume control potentiometer and a Bluetooth control button.
The Wondom AA-JA32151 JAB 1 is a versatile Bluetooth 2.1 stereo amplifier module delivering 2x15W at 8Ω. This new wondom JAB series offers amplification modules for mobile use. They are optimized for Lithium battery operation. It is possible to use them in mono mode (BTL).
The Bluetooth 4.0 aptX Wondom BRB4 receiver will allow you to stream your music via Bluetooth while enjoying excellent sound quality. Indeed, this module ensures low noise and low distortion. In addition, its aptX, A2DR and +EDR technologies provide optimal transmission quality and stability.
