Pack Tonewinner AT-300 AV Processor + 2x AD-5100PA+ Power Amplifier + ETM-2 Measurement Microphone
This Tonewinner pack includes the AT-300 audio/video processor and home theater preamplifier, plus two AD-5100PA+ power amplifiers. The result is an extremely powerful, high-performance home theater system. What's more, these devices feature a unique design for aesthetic integration into your audio system. The package is completed by the Tonewinner ETM-2 measurement microphone, enabling easy acoustic correction to optimize sound reproduction according to the acoustics of your listening room.
By buying this product you get 219 loyalty points
Reference : 20759
2 199,00 €tax incl.
1 832,50 € tax excl.
Instead of 2 596,00 €
Pack content
Pack Tonewinner AT-300 + AD-5100PA+ + ETM-2 AV Processor + 2x 5 Channels Power Amplifier + Measurement Microphone
Pack Tonewinner AT-300 Audio-Video Processor + 2x AD-5100PA+ Power Amplifier + ETM-2 Measuring Microphone
Tonewinner AT-300: AV processor / home theater preamplifier
The Tonewinner AT-300 is a 16-channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio formats, including Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-300 accepts video streams up to 4K UHD 60Hz, and is compatible with HDR, HDR10 and Dolby Vision technologies. This means you can enjoy the latest and greatest formats available for the most immersive sound and visual experience possible.
FIND OUT MORE ABOUT THE TONEWINNER AT-300
Tonewinner AT-300 AV processor / home theater preamplifier
Tonewinner AD-5100PA+ 7-channel power amplifier
Tonewinner AD-5100PA+: 7-channel power amplifier
The Tonewinner AD-5100PA+ is a Class AB power amplifier with 5 channels capable of delivering 130W into 4Ω or 90W into 8Ω each. This makes it ideal for integration into a home theater system. It uses 5 pairs of Toshiba TTC5200 and TTA1943 transistors, ensuring rich, musical sound reproduction. The low-noise differential amplification circuit provides a clear improvement in SNR and dynamics.
This Tonewinner pack contains two Tonewinner AD-5100PA+ amplifiers.
FIND OUT MORE ABOUT THE TONEWINNER AD-5100PA+
Tonewinner ETM-2: Measurement microphone
The Tonewinner ETM-2 measuring microphone is designed to enable you, in conjunction with certain Tonewinner home theater systems, to automatically correct the acoustics of your system. It connects to the AT-2300, AT-2000, AT-300 and AD-7300HD models and applies optimal equalization to your loudspeakers for perfect immersion and sound coherence.
FIND OUT MORE ABOUT THE Tonewinner ETM-2
Product typeA/V processor + 2x Power amplifiers + Measurement microphone
Tonewinner AT-300 specifications
Home theater preamplifier
Channels16 channels
InputsBluetooth
6* HDMI 2.0
4* Stereo RCA
2* Coaxial
2* Optical Tolsink
1* Slot Micro SD
1* Mini USB (USB Audio)
1* USB-A (USB Host)
OutputsBluetooth
2* HDMI 2.0 (with 1 eARC)
RCA 9.3.4 channels
XLR 9.1.4
Other connectors1* RS232
1* 5V trigger output
Supported audio formatsDolby Atmos
Dolby True HD
Dolby Digital Plus
DTS/X
DTS Master
DTS Hi-Res
DTS Upmix
DTX Neural:X
Supported video formats / resolutions4K UHD
3D
Dolby Vision
HDR10 / HDR10+
HLG
HDCP version2.2
eARC supportOn one output
CEC supportOn 5 inputs
Automatic EQ calibration
Lip syncUp to 1000ms
DRC feature
Input impedance20kOhm
Output impedance1kOhm
Gain>= 14dB
THD<= 0.02% (1kHz)
SNR>= 98dB (A-wt)
Frequency response10Hz-50kHz (+1/-3dB)
Channel separation>= 80dB
Crosstalk>= 80dB
Supply voltage100-240VAC 50/60Hz
Dimensions431*326*100mm
Weight4.4kg
Tonewinner AD-5100PA+ Specifications
Product typePower amplifier
Amplification typeClass AB
Channels5
Inputs5* RCA
OutputsSpeaker terminals
Output power5x130W @ 4 Ohm
5x90W @ 8 Ohm
Impedance8 Ohm
Channel separation>= 70dB
THD<= 0.1%
SNR>= 100dB (A-wt)
Frequency response20Hz-30kHz (+1/-3dB)
Supply voltage115-230VAC 50/60Hz
Dimensions431*352*130mm
Weight9.6kg
Tonewinner ETM-2 specifications
Product typeMeasurement microphone
CompatibilityTonewinner AT-300
Tonewinner AT-2300
Tonewinner AT-2000
Tonewinner AD-7300HD
Sensitivity-40dB
DirectivityOmnidirectional
Microphone connectorXLR
Cable connectorJack 3.5mm
Cable length5m
InputMicro SD
InputHDMI
OutputSpeaker terminal
OutputHDMI
OutputHDMI eARC
OutputBluetooth
Channel5
Channel10
ClassClass A / AB
Amplifier chipTransistors
Power (W)130.0
Remote ControlYes
This Tonewinner pack includes the AT-300 audio/video processor and home theater preamplifier, plus two AD-5100PA+ power amplifiers. The result is...
