JANTZEN AUDIO Gold plated Binding posts 20mm (Pair)
JANTZEN AUDIO Gold plated Binding posts 25mm (Pair)
Reference : 9734
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Jantzen Audio Speaker terminals 20mm
Gold-plated / sold by 2 units (red + white)
These terminal blocks are designed for mounting on boxes and enclosures with a thickness of 20mm or less. The connectors are gold plated to ensure excellent conduction of the audio signal.
They can receive a bare speaker cable via a screw-in insert, allowing cable conductors up to ⌀5mm - as well as audio banana plugs (4mm).
The end piece intended to be connected to the loudspeaker is connected by soldering.
TypeSpeaker terminals
ContactsGold6plated
FinishNickel
Max panel thickness20mm
Max cable diameter4 mm
Accepts banana plugsYes (4mm)
Fixation (towards speaker)Solder
Fixation (towards amplifier)scew / banana plug
MarkingsColor : white + red
Screw Thread8.8 mm
Max length70 mm
Max width22 mm
Screw length33 mm
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)20.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
4 reviews
Superbe et pratique à l'usage
Excellent produit, avec une qualité de conception et de construction exemplaire.
Attention ce sont des borniers aux dimensions pour le moins généreuses à réserver aux enceintes de moyennes supérieures et grosses.
Je recommande pleinement
This review has been posted for JANTZEN AUDIO Gold plated Binding posts 20mm (Pair)
Vraiment superbe sans se ruiner!
Very good
Very good binding posts for it's price, well very good in any terms. Accepts bare wire, forks and bananas. Has a good soldering option for internal wire and has good insulation. Might feel a bit loose parts when not installed in place, but are solid after they've been put together and tightened. Have bought them already several pairs and will buy more in future.
Quality binding posts
Very good and robust looking binding post and heavy in weight.
These Jantzen will not be my last .
 (3)
