O top de qualité!
Montage facile grâce au gabarit.
Très bonne achat
WBT-0763 Gold plated midline speaker terminals (set x4)
Since we know that a simple electrical wire is not enough to connect an amp and a H.P., we have become used to using cables with a large cross-section, which has had certain repercussions on the terminal blocks...
This type of connector is faced with two imperatives:
Not only do they have to accept large cable cross-sections, but above all they have to ensure excellent conductivity through extreme tightness.
The truth is not in the giant terminals, but rather in the robust mechanical design.
The integrated retaining mechanism (WBT patent) holds the banana plug firmly in place when the front lock nut is tightened and thus not only protects the connection against accidental disconnection but also ensures an extremely high contact pressure.
Features :
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
