WBT-0763 Speaker Terminals
WBT-0763 speaker terminal blocks are 24k gold-plated, multilayer polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design.
Reference : 6861
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 09-05-2025.
WBT-0763 Speaker Terminals Midline Classic Gold-plated 24k (Set x4)
Photo of WBT-0763 speaker terminals
WBT-0763 speaker terminal are 24k gold-plated, multilayer polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design. In fact, they ensure a high level of contact pressure. All these features enable them to accept large cable cross-sections while maintaining excellent conductivity. An integrated clamping system protects the banana plug connection from accidental disconnection. Puzzle plates (mounting insulators) complete the package for simplified installation. These terminal blocks are part of the classic WBT range.
If you are using WBT-0735 for bi-wiring, and wish to combine them with WBT-0725 short-circuit bridges, the terminal blocks must be mounted separately, i.e. without the connecting tab. Make sure to maintain a minimum distance of 30 mm (terminal center to terminal center). The distance to the second pair of terminal blocks must be exactly 60 mm.
Zoom in on a WBT-0763 terminal block
Product typeSpeaker terminal
ConceptionMonobloc
Contact materialCopper alloy
COntact plating24k Gold
CompatibilityBanana plugs 4mm
6 or 8mm spades
Bare crimped wire
Max. conductor cross-sectionExternal : 6mm² (9 AWG)
Internal : 10mm² (AWG 7)
Internal connectionCrimping or soldering
Max. panel thicknessFrom 0.1 to 10mm
Identification rings2x red
2x white
Gross weight225g
Package4x WBT-0763 speaker terminals
Mounting typeTo screw
Mounting typeTo connect
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
WBT bellissima
O top de qualité!
Montage facile grâce au gabarit.
Très bonne achat
This review has been posted for WBT-0763 Speaker Terminals Gold Plated (set x4)
WBT-0763 speaker terminal blocks are 24k gold-plated, multilayer polished for maximum resistance to corrosion and oxidation. They meet the most...
