No featrued products
Angled SATA 3.0 6GB/S 35cm
SATA 3.0 cable with a bandwidth up to 6GB. It can connect together your hard drives & motherboards / peripherals equipped to work with SATA storage.
The connector is equipped with a stainless steel latch to ensure optimal contact even when mounted into an environment subject to vibrations or shocks. Likewise, its generous 26AWG section makes it a reliable cable over time.
With a length of 40cm and provided with a angled connector, this cable is a safe and efficient solution to add significant storage to your do it yourself creations.
SPECIFICATIONS | |||
Type | SATA Cable Angled | ||
Norm | SATA 3.0 | ||
| Max Bandwidth | 6 GB/s | ||
| Cross Section | 26AWG | ||
| Length | 35 cm | ||
| Length (m) | 0.3 |
| Shielding | NC |
| Section (mm²) | 0.129 |
| Connector | SATA |
| Conductors material (Cable) | N/A |
| Conductors Plating (Cable) | None |
