Happy with the result. Need another 3m piece
OFC Copper Speaker Cable 2x4.mm² Ø12mm
Mogami 3103 is a high quality speaker cable designed to allow your audio devices and speakers to reach their full potential. Each conductor, with a cross-section of 4mm² (12AWG), is made from OFC Mogami Neglex Copper in a configuration designed to provide transparency and sound precision. The cable can be used both at home and for professional purposes.
Product type | Speaker cable |
Conductors number | 2 |
Conductors material | OFC Copper |
Conductors section | 4mm² (12AWG) |
Conductors insulation diameter | Ø4.5mm |
Insulation material | PVC |
External diameter | Ø12mm |
External sheath material | Flexible PVC |
Weight / 100m | 20kg |
DC resistance | 0.005Ω/m |
Inductance @ 20°C 1kHz | 0.6µH/m |
Capacitance @ 20°C | 100Hz : 106pF/m 1kHz : 93pF/m 10kHz : 83pF/m 50kHz : 76pF/m 100kHz : 74pF/m |
Max. voltage | 500V DC (15s) |
Working temperature min / max | -20°C / +70°C |
Quantity | Cable sold per meter |
Diameter (mm) | 12.0 |
Length (m) | Sold by length |
Number of conductors | 2 |
Shielding | No |
Section (mm²) | 4.00 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | No |
Average votes 4.9 / 5 91 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Gurhan O.
Emilio L.
Canzar V.
CASPAR P.
Christian B.
