HIFIMAN CRYSTALLINE Balanced Jack 3.5mm to 2x Jack 3.5mm Cable OFC Copper 1.5m
This Hifiman CRYSTALLINE 1.5m OFC cable has been specially designed for HE series headphones. It is intended to replace the basic cables supplied with these headsets. The cable uses silver-plated stranded OFC copper as conductors for maximum conductivity. OFC (Oxygen Free Copper) allows increased signal precision and performance.
Reference : 15319
129,00 €tax incl.
107,50 € tax excl.
Hifiman CRYSTALLINE
Balanced Jack 3.5mm to 2x Jack 3.5mm cable for HE series OFC Copper 1.5m
Hifiman Câble Hybride OFC Jack 3.5mm vers Jack 2.5mm pour Casque Hifiman Série HE 3m
This Hifiman CRYSTALLINE 1.5m OFC cable has been specially designed for HE series headphones (HE400S, HE400i, HE560, HE1000 & Edition X). It is intended to replace the basic cables supplied with these headsets. The cable uses silver-plated stranded OFC copper as conductors for maximum conductivity. OFC (Oxygen Free Copper) allows increased signal precision and performance.
3.5mm TRS Jack connectors make it easy to insert and remove the cable from the headphones.
TypeJack cable
Length1.5m
Connectors1x Jack 3.5mm TRRS
2x Jack 3.5mm TRS
ConductorsOFC Copper
Plating
Connector : Gold
Conductor : Silver
SheathNylon
Length (m)1.5
Section (mm²)N/A
ConnectorJack 3.5mm
This Hifiman CRYSTALLINE 1.5m OFC cable has been specially designed for HE series headphones. It is intended to replace the basic cables supplied...
