No featrued products
The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire RCA to 3.5mm stereo jack cable features a Sommercable ONYX 2025 MKII modulation cable, Amphenol ACPR male RCA connectors and a Neutrik REAN NYS231BG-LL 3.5mm jack connector, ensuring excellent conductivity and durability for efficient audio signal transmission.
Sommercâble Onyx interconnect cable is an unbalanced cable with a cross-section of 2x0.25mm² (AWG 24). This flexible cable is made up of fine OFC copper strands. In addition, it benefits from PE insulation and Cu spiral shielding per conductor, effectively protecting it from EMI/RFI interference.
This Audiophonics Wire RCA cable is terminated on both sides with Amphenol ACPR male RCA connectors. These maintain a very good level of conductivity thanks to 24k gold plating while ensuring excellent durability thanks to a high resistance to oxidation. The body of the connectors is made of die-cast nickel and is equally robust.
This 3.5mm stereo male jack connector features a high-quality design with gold plating on the contacts, favoring conductivity and resistance to oxidation. In addition, its anodized metal body guarantees sturdiness and durability.
| Specifications | |
| Product type | Interconnect cable |
| Connectors | 2x male RCA 1x 3.5mm male stereo jack |
| Length | 0.75m |
| Sommercable Onyx 2025 MKII cable specifications | |
| Conductors material | OFC Copper |
| Conductors cross-section | 2x0.25mm² (24AWG) |
| Conductors diameter | 32 x Ø0.10 mm |
| Insulation material | PE |
| Outer sheath | PVC |
| Amphenol ACPR RCA connector specifications | |
| Contact material | Copper alloy |
| Contact plating | 24k gold |
| Body material | Nickel |
| Insulation | PA66 |
| Neutrik REAN NYS231BG-LL connector specifications | |
| Contact plating | Gold |
| Body material | Anodized metal |
| Pole numbers | 3-pole (TRS) |
| Length (m) | 0.75 |
| Shielding | Yes |
| Section (mm²) | 0.25 |
| Connector | Jack 3.5mm |
| Connector | RCA |
| Conductors Plating (Cable) | None |
