No featrued products
Male Mono RCA to Male Mono Jack 3.5mm Gold Plated 1.8m
This cable consists of a mono mâle RCA connector and a mono mâle 3.5mm jack. It may therefore allow you to connect some mono devices with these connections, such as the mono amplifier Audiophonics TPA-M50 which only has a 3.5mm mono jack connector at its input. The cable is also compatible with the Coaxial input in 3.5mm Jack format from SMSL AD18. In addition, the cable connectors are gold-plated to ensure good conductivity and oxidation resistance.
| Specifications | |
| Product type | Male mono Jack 3.5mm to male mono RCA cable |
| Length | 1.8m |
| Connectors plating | Gold |
| Color | Black |
| Length (m) | 1.8 |
| Shielding | NC |
| Section (mm²) | N/A |
| Connector | RCA |
| Connector | Jack 3.5mm |
| Conductors Plating (Cable) | None |
