Adapter Cable Male 4 Pins XLR to Female Jack 4.4mm Gold Plated 15cm
This symmetrical adapter cable has a 4-pin XLR male connector and a 4.4mm female jack connector. It will therefore allow you to connect symmetrical high-end HiFi devices in order to enjoy the audio quality inherent in this type of transmission.
4.8 / 5
Reference : 13867
34,90 €tax incl.
29,08 € tax excl.
Last items in stock !
Shipping date: 07-05-2026.
Adaptateur XLR / Jack 4.4mm
âble Adaptateur XLR Mâle 4 Pins vers Jack 4.4mm Femelle Plaqué Or 15cm
This symmetrical adapter cable has a 4-pin XLR male connector and a 4.4mm female jack connector. It will therefore allow you to connect symmetrical high-end HiFi devices in order to enjoy the audio quality inherent in this type of transmission. In addition, the connectors are gold plated to ensure very good conductivity and oxidation resistance.
Product typeBalanced Adapter Cable XLR / Jack 4.4mm
Connectors1x Male 4 Pins XLR
1x Female Jack 4.4mm
Length15cm
Connectors contacts platingGold
Transmission typeBalanced
Cable shieldingYes
Cable diameter5.5mm
Length (m)0.1
ShieldingYes
Section (mm²)N/A
ConnectorXLR
ConnectorJack 4.4mm
5 reviews
Un adaptateur de très bonne qualité.
Cet adaptateur est fabriqué avec des prises tout en métal. Les contacts sont "francs" et sans jeu. Sa longueur est bien adaptée et son prix est compétitif. Je recommande
This review has been posted for Adapter Cable Male 4 Pins XLR to Female Jack 4.4mm Gold Plated 15cm
Très bon adaptateur
Utilisé sur un DAC TOPPING EX5, des écouteurs FIIO FH7 et un câble de remplacement FiiO LC-4.4D 4.4mm (introuvable en France...).
Le serrage est parfait. Cet adaptateur est suffisamment flexible, résistant et respire la qualité tant physique qu'au niveau du son.
Utilissimo
Per chi possiede una cuffia con cavo bilanciato terminato con jack 4,4 mm
(tipo Sennheiser HD800S) questo adattatore si rivela utilissimo per la connessione ad amplificatori con uscita bilanciata XLR 4 poli, senza dover acquistare il cavo originale dal costo elevato. L'oggetto è ben realizzato, elegante e costa veramente poco. Cosigliatissimo.
Works very well
I have just received and tested my order.
Works very well. Transport took a bit longer (France to Germany) but that may be caused by the pandemic.
Recommend this shop/product.
c'est bien
fait son boulot mais la fiche 4.4 mm de mon casque semble rentré trop facilement . pas assez serrer .
This symmetrical adapter cable has a 4-pin XLR male connector and a 4.4mm female jack connector. It will therefore allow you to connect symmetrical...
