By buying this product you get 34 loyalty points
2x Mini XLR to XLR 4 Pins Balanced PCUHD Copper 2.5m
This balanced Meze cable was specifically designed for use with headphones. It features an exceptional design, using Furukawa PCUHD copper conductors, ensuring incredible electrical conductivity for perfect audio signal transmission. Furukawa cables are known for their ability to provide open, yet highly detailed sound with perfectly controlled transients and punchy bass.
By combining a molding process with a post-treatment that does not use hot extrusion or lamination, no impurities corrupt the conductors. Also, no gas burners are used in the manufacturing process to ensure that the oxygen level in the copper is perfectly controlled, as it is measured at 5ppm, which is lower than the standard required for OFC (Oxygen Free Copper).
Regarding the connectivity of this cable, it has two Mini XLR connectors and a 4.4mm jack connector, allowing a balanced connection. Each connector is equipped with gold-plated contacts, to maintain excellent conductivity and durability.
Product type | Headphone balanced cable |
Length | 2.5m |
Connectors | 2x XLR 4 pins 1x Jack 4.4mm |
Cable conductors material | PCUHD Copper |
Conductors composition | 140*0.04mm |
Sheath material | TPE |
Soldering | Jensen Silver 4% |
Length (m) | 2.5 |
Shielding | NC |
Section (mm²) | N/A |
Connector | XLR |
Connector | Mini XLR |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
