0.5ps +/-10ppm LVCMOS
This 22.572Mhz clock provides stability and accuracy for low jitter. It has a LVCMOS output format to the SMD / SMT standard.
It will replace any compatible 22.572Mhz clock, offering performances close to American, British or Japanese references, for a much lower price.
The benefits of a quality clock are well known to audiophiles, offering a less aggressive sound on high definition files.
Caution: This clock requires a soldering station suitable for hot air type SMD components. Do not attempt to solder with a conventional soldering iron.
Frequency | 22.572Mhz |
Frequency stability | +/-10ppm |
Phase jitter | 0.5ps |
Voltage supply | 1.8, 2.5 à 3.3V |
Output type | LVCMOS |
Connection type | SMD/SMT |
Operating temperature | -20°C to 70°C |
Dimensions | 7 x 5 x 0.85mm |
