AUDIOPHONICS EVO-SABRE Balanced DAC 2x ES9038Q2M USB GPIO Raspberry Pi SPDIF Bluetooth XLR RCA
AUDIOPHONICS DAC Balanced I-Sabre 2x ES9038Q2M SPDIF USB BT / XLR RCA
Direct successor to our famous DAC I-Sabre ES9038Q2M module, the EVO-SABRE 2x9038Q2M is a balanced version of the converter with a full range of connectors and input interfaces (SPDIF Coaxial and optical, USB, Bluetooth and I2S through GPIO). This version is more precise, more efficient and more versatile. It includes its own microcontroller, a digital OLED display with encodder and can work in total autonomy.
4.4 / 5
By buying this product you get 20 loyalty points
Reference : 14562
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Audiophonics EVO-SABRE
Module DAC Double SABRE ES9038Q2M Balanced SPDIF / USB / RPI 4 & Stand-alone
Audiophonics EVO-Sabre DAC Symétrique 2x ES9038Q2M USB GPIO Raspberry Pi SPDIF Bluetooth XLR RCA
Of course there is still a GPIO connector with I2S input allowing the mounting of a Raspberry Pi (or some other SBC) to obtain a complete solution including both a digital audio source and a very high definition digital to analog decoding - with tremendous audio quality for its price range. Just pick and install one of the many free streaming software solution and connect the board to an amplifier or active speaker to enjoy a complete, ready-to-use high-fidelity package loaded with audio features.
The case kit associated with this DAC EVO-SABRE is available here : AUDIOPHONICS EVO DAC Aluminum case and accessories kit Black.
Here you may find a kit including all required parts to assemble a complete EVO SABRE DAC Streamer using 100% of its capacities : DAC module, Remote control, Housing, Power supply and Raspberry Pi.
ASR Review
I am happy to recommend the Audiophonics EVO Sabre given the unique functionality, form factor, and performance.
 test by the measurement forum Audio Science Review
Balanced ES9038 DAC
The EVO-Sabre is a high-precision DAC using two 32-bit ES9038Q2M Sabre chips integrated in dual Mono mode: each of these chips see its computing power 100% dedicated to a single channel of the stereophonic signal. This achieves a sound restitution of exceptional clarity with tremendously low crosstalk.
This component belongs to ESS flagship series and is among the best current hardware solutions for high-fidelity audio decoding. It uses HyperStream 32 BIT 768kHz architecture with native DSD support. Each one of this chips is also equipped with advanced reconstruction filters and uses some of the finest dithering techniques available on the audio market.
ESS ES9038Q2M SABRE DACs are also very popular thanks to their ability to operate volume with almost no consequences on the audio bitrate.
The board works in balanced and single-ended mode and offers both a balanced stereo output on 3-pole XLR connector and an single-ended stereo output on RCA connector. The module can thus be ideally suited to most integration scenarios and will easily find its place in minimalist audio projects as well as in very complex Hi-Fi installations.
Basic connections
Ports audio Sabre Evo Audiophonics
AXLR Output (balanced)
BCoaxial Input S/PDIF
CGPIO Connector
DRCA Output (single-ended)
EOptical Input S/PDIF
FUSB-2 type B Input
GBluetooth
HPower-supply 9V Jack DC
Both outputs (RCA & XLR) are active at the same time.
XMOS U208 USB Interface
The USB-B input (USB-2) works with a XMOS U208 USB interface. This is a reference component in the field of high-fidelity music, with digital streams supports up to 32-bit 768kHz as well as (native) DSD512.
Definitely designed for high-resolution, this asynchronous USB interface has a computation capacity of 1000 MIPS all of which is dedicated to the processing of your digital audio signals with minimal jitter and noise.
When the DAC EVO-SABRE is used in conjunction with a Raspberry Pi, this high-definition USB input allows to immediately interface digital audio streams to RPI I2S up to 384kHz / DOP 128.
FGPA Altera Max
Unlike its predecessor, the EVO-SABRE has several inputs driven by an independent interface.
SPDIF signals are handled by a FGPA Altera Max capable of performing clean processing of the digital input streams. These digital signals are interfaced in I2S to each of the two DAC chips, which represents a significant gain in performance compared to previous generations.
The SPDIF inputs support PCM signals up to 24/192 as well as DSD 128 DOP streams.
Microcontroller autoconfiguration
Thanks to an integrated microprocessor, the EVO Sabre automatically detects the format & the sampling rate of the signal source and will automatically adapt its configuration to provide the best listening performance without requiring any user intervention.
This control by CPLD chip maintains great stability while preventing decoding problems as well as the appearance of audio artifacts.
It also enables a continuous decoding of playlists with heterogeneous file types without having to worry about reconfiguring the DAC to benefit from optimal audio quality.
Optimized power stage
Powered by a DC 9V jack connector, the module operates from a particularly well designed power stage which allows to ensure a stable signal while reducing residual noise.
For this purpose, the PCB has a Mornsun DC / DC converter followed by two voltage regulators 79M08 / 78M08 dedicated to the analog part with is powered with +/- 8V.
The card has a separate 5V power stage dedicated to the Raspberry Pi. In this scenario, the RPI is supplied directly via its GPIO port, avoiding the need to add more connections and cables. Every configuration uses the minimum amount of cables for increased ease of use.
The card also has Ultra low noise voltage regulators dedicated to the conversion stage in order to isolate the DACs from the main power supply.
The DVCC voltage is generated from an LP5907 (regulation <6.5µV), which generates the DAC 1.2V Vref which is a critical voltage.
The AVCC voltage is generated from a dedicated ADP150 regulator (regulation <9µV).
OLED screen, controller, I/R receiver, ON/OFF switch
A second PCB is included witrh the module. This secondary board is equipped with an ON / OFF switch, an infrared receiver, an OLED screen and a rotary encoder which are already mounted.
The switch is backlit when the module is in standby to indicate that the circuit is ready for operation.
The 1.3"128X64 OLED screen simultaneously displays the active input, the sampling rate and the volume as defined by the DAC ES9038Q2M chip-specific control. This feature is usefull to check in real time that the playback is going as planned.
The rotary encoder on the far right is directly connected to the volume control of the DAC chips. It allows easy and precise volume adjustment the from the device front panel.
Finally, the infrared receiver communicates both with the microcontroller in charge of driving the DAC chips and with the Raspberry Pi if the EVO-SABRE is used in network drive mode with LIRC configured. The remote control (included) thus centralizes most of the playback functions for great ease of use.
The input selection, volume and standby functions, as well as the filters adjustements are handled by the integrated microcontroller, while the play / pause, previous / next functions are transmitted to the RPI (requires LIRC configuration on GPIO 04)
d
Connector for secondary display
In addition to its display / controller / receiver PCB, the DAC EVO SABRE Audiophonics ES9038Q2M module has an additional connector intended to receive a second 3.12 "256x64 OLED screen connected directly to the Raspberry Pi SPI (CN4).
A pre-configured script to install on your Pi4 is available to directly extract the playback data (Dietpi / LMS). Users versed in Python / UNIX programming can easily adapt or recreate a script to modify its behavior to their liking.
It is then possible to achieve very clever integration for your DAC/Streamer with on the one hand a compact screen / controller dedicated to audio parameters and on the other hand an auxiliary screen dedicated to the metadata of your tracks as well as general parameters related to your project.
Use with Rasperry Pi
The Raspberry Pi is not supplied with the EVO SABRE module. This optional element considerably widens the functionality of the module. Click here to find the suited version.
Used in conjunction with a Raspberry Pi 3 or 4, the EVO-SABRE ES9038Q2M becomes a complete dematerialized streaming solution.
The pinout is the most common, compatible with the RPI-DAC driver and present in all distributions.
It is also possible to use the driver for the I-Sabre 9038, found in the Raspberry PI kernel from version 4.19.34.
This allows you to control the volume of the chip directly from the RPI, but the interest is limited insofar as the EVO-SABRE already offers these functions with its remote control and the front encoder.
FFT Measure
TypeDAC Module
DAC chip2x ESS ES9038Q2M
ArchitectureBalanced
Audio InputsS/PDIF Coaxial
S/PDIF Optical
Bluetooth HD (Bluetooth antenna available here)
USB-B (XMOS)
I2S GPIO (pinout RPI-DAC)
Audio OutputsRCA stereo single-ended (2V RMS)
RXL stereo balanced (4V RMS)
Sampling rate
USB : 768kHz / DOP256
RPI I2S : 384kHz / DOP128
SPDIF : 192kHz / DOP64
Power Supply9VDC (2A minimum) on jack DC 5.5 / 2.1mm (Power supply not included)
Idle consumption700ma
USB interfaceXMOS U208
FGPAAltera Max
Dimensions
Main PCB : 120 x 225mm (Max height : 32mm)
display PCB : 40 x 134 mm
Weight185g
InputGPIO
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD256
10 reviews
Ver nice DIY plug and play device
Works best with Volumio, in my opinion. With Volumio and the audiophonics-volumio-plugin, it is possible for me to skip tracks, control volume and shutting down proper with the remote control. Sound is very good - better than Topping DX3pro+, imo.
I paired it with pi3B+, 1GB RAM. Works fine! I build a case out of thin wood plates. Now, got a very good all-in-one STREAMER/DAC for 260 Euro!!! Nice!
But please Audiophonics-Team, make a big HINT in Github, that the old procedure of changing the kernel of raspy in order to get the I-Sabre-driver working, is NOT necessary anymore, because it is implemented in the newer os versions. That costs me hours of work, when i prepared a OS for plexamp!!!
This review has been posted for AUDIOPHONICS EVO-SABRE Balanced DAC 2x ES9038Q2M USB GPIO Raspberry Pi SPDIF Bluetooth XLR RCA
excellent
j'avais l'ancien modèle dont j'étais très satisfait.
Suite à sa panne, j'en ai profité pour une mise à jour.
Encore mieux.
Pour ceux qui o,t une imprimante 3d, je mets à dispo un boitier :
https://www.thingiverse.com/thing:6473605
bonne écoute,
Emballage un p
Pour ce type de produit haut de gamme, je m'attendais à le voir fourni dans une boite et avec un guide d'utilisation et de branchement. J'ai donc été déçu de le voir emballé dans une enveloppe à bulles entourée d'une feuille de carton et sans aucun document d'accompagnement (heureusement il y a de la documentation sur le site). Donc emballage robuste mais pas très "classe" pour ce produit "Hi-Tech". Sinon, le produit à l'air de qualité.
Très satisfait
Très pratique à l’usage , à l’écoute je l’ai trouvé très ”vivant” belle dynamique, je le préfère à mon ex auralic pour beaucoup moins chère en prime.
Good but could be better
I bought this DAC and a Linear Power Supply, initially I had some trouble with the power supply but now it works well. I had to pay the assistance, Audiophonics team said that everything was ok, but I sent a non-working things and received back a working one... But all's well that ends well, as the old boot said.
The main problem is that the Pi isn't shutdown well.
I bought this to substitute a Cocktail Audio, looking for a better sound.
The usability feature on the cocktail audio are better, the touchscreen and the interface are very well made. I hoped that this could be like the Cambridge Audio but the only way to use Raspberry with Volumio is through another interface.
The remote control and the knob aren't useless to navigate inside the library.
The sound of the DAC is good, better than Cocktail Audio.
The unclean poweroff of the Pi is the biggest minus.
I didn't understand if there is one or more pin of Raspberry GPIO available for custom usage.
Direct successor to our famous DAC I-Sabre ES9038Q2M module, the EVO-SABRE 2x9038Q2M is a balanced version of the converter with a full range of...
