AOSHIDA D7 Tube Preamplifier / Headphone Amplifier / DAC CS4344 Bluetooth 5.1 QCC5152 aptX HD LDAC
The Aoshida D7 is a hybrid concept, fulfilling the functions of a DAC, tube preamplifier and headphone amplifier at the same time, all for a contained price. Its performance is not to be outdone. Its digital/analog conversion stage is equipped with a CS4344 DAC chip offering a detailed and dynamic sound. The preamplification section is entrusted to a pair of 5725 tubes that soften the sound signature of the device.
Reference : 16892
139,00 €tax incl.
115,83 € tax excl.
Aoshida D7
DAC CSR4344 / Tube Preamplifier / Headphone Amplifier Bluetooth 5.1 QCC5152 aptX HD LDAC
Aoshida D7 DAC CS4344 / Préamplificateur à tubes / Amplificateur casque Bluetooth 5.1 QCC5152 LDAC
As for its connectivity, the Aoshida D7 is equipped with a single-ended RCA and balanced XLR input and output. Connectivity completed by a headphone output in front of the 3.5mm jack, but also, thanks to its QCC2125 chip, by a Bluetooth 5.1 reception capacity that will allow you to easily and quickly broadcast your music from a smartphone or a tablet. The LDAC transmission codec is also supported for high-quality wireless sound reproduction with a sampling rate of up to 96kHz.
1Jack 3.5mm headphone output
2IR receiver
3Multifunction button
4OLED screen
5Volume- button
6Volume+ button
7Single-ended RCA input
8Bluetooth antenna
9Balanced XLR output
10Single-ended RCA output
11Balanced XLR input
1212VDC power input
Product typeDAC
Tube preamplifier
Headphone amplifier
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Bluetooth 5.1
1x Jack 3.5mm headphone output
Frequency response20Hz~20kHz (±1dB)
Input sensitivity1Vrms
Distortion degree0.05%
SNR≥103dB
Headphone impedance range16-300Ω
Headphone output power120mW
Max RCA output amplitude2V
Max XLR output amplitude4V
Dimensions170*126*42mm
ColorGray
Package1x Aoshida D7
1x Bluetooth antenna
1x Remote control
1x Power supply
InputXLR
OutputJack 3.5mm
ColorGray
Remote ControlYes
The Aoshida D7 is a hybrid concept, fulfilling the functions of a DAC, tube preamplifier and headphone amplifier at the same time, all for a...
