GUSTARD R30 DAC R2R Preamplifier Streamer Black
New
The Gustard R30 is a DAC, streamer and preamplifier based on an R2R ladder resistor network to offer high-precision digital-to-analogue conversion, supporting PCM up to 32-bit 1536kHz and DSD up to DSD1024 for faithful and detailed reproduction. Its extensive connectivity allows it to be integrated into a wide range of audio setups. Based on CelWare 3.x software, it supports Roon Bridge, AirPlay, HQPlayer NAA, UPnP, mConnect, Bubble UPnP, Spotify and QQMusic.
By buying this product you get 359 loyalty points
Reference : 21047
3 590,00 €tax incl.
2 991,67 € tax excl.
Gustard R30 DAC R2R Preamplifier Streamer 32bit 1536kHz DSD1024 Black
Gustard R30 : Front view
The Gustard R30 is a DACstreamer and preamplifier based on an R2R ladder resistor network to offer high-precision digital-to-analogue conversion, supporting PCM up to 32-bit 1536kHz and DSD up to DSD1024 for faithful and detailed reproduction. Its extensive connectivity allows it to be integrated into a wide range of audio setups. Based on CelWare 3.x software, it supports Roon Bridge, AirPlay, HQPlayer NAA, UPnP, mConnect, Bubble UPnP, Spotify and QQMusic.
The Gustard R30 does not support standalone network playback (it cannot directly access streaming services) and requires the use of a third-party application (such as BubbleUPnP, Mconnect, Roon, or Audirvana, for example) for music control and playback.
Gustard R30: 27-bit R2R DAC
The heart of the R30 is based on a discrete 27-bit R2R architecture, where the signal is processed by a ladder resistor network rather than a conventional conversion chip. This approach allows for fully analogue conversion, without complex digital interpolation. Unlike delta-sigma DACs, which use noisy modulation and massive oversampling, the R2R works directly on the native resolution of the signal.
The R30 implements 1-bit analogue decoding, designed to handle the DSD stream purely in hardware, without prior conversion to PCM. This preserves the integrity of the DSD signal, avoiding distortions and artefacts associated with intermediate conversions. The device thus supports native DSD1024. This is accompanied by a custom-optimised low-pass filter, which complements the conversion stage by ensuring a smooth and controlled frequency response.
Gustard R30 : R2R module
Gustard R30 : Digital filter module
Gustard R30: Latest generation digital filter
The R30 incorporates a new-generation digital filter capable of upsampling the signal while effectively reducing associated noise. This processing step also eliminates aliasing distortion present in the bandwidth inherent to the conversion process. The signal thus retains its integrity, with purer and better-defined reproduction across the entire audible spectrum.
Gustard R30: OCXO clock and GCLK-02 module
The time section is provided by a thermostabilised OCXO clock, offering high precision and optimal stability in the presence of temperature variations.
The OCXO clock is paired with a GCLK-02 clock module, a high-performance clock frequency synthesiser that uses advanced PLL (Phase Locked Loop) technology to ensure the stability and accuracy of the signal produced. The design of this module allows it to use either a local clock source (in this case, OCXO) or an external 10MHz clock signal, offering you a high-quality and flexible clock solution.
Here, the R30 can also be synchronised with an external clock via its 50 Ω BNC input, which is compatible with a square CMOS signal (0.2–3.3 V) or a sine wave (0.5–3.3 V).
Gustard R30 : GCLK-02 module
Gustard R30 : FPGA
Gustard R30: Gustard's FPGA
The R30 features a proprietary Gustard FPGA responsible for signal reconstruction and advanced digital stream management. It handles clock signal distribution and processing, PLL (Phase Locked Loop) shaping, DoP demodulation, and reduction of switching noise in PCM and DSD signals. This integration enables precise control of each stage, ensuring stable and optimised conversion.
Gustard R30: Analogue preamplification
In addition to its DAC function, the R30 can be used as an analogue preamplifier. The volume control is based directly on its R2R network, enabling lossless attenuation control. A bypass mode is available to disable the preamplifier section if necessary. Thanks to this design, the R30 can be connected directly to a power amplifier or active speakers, simplifying integration into a high-fidelity audio system.
Gustard R30 : preamplification stage
Gustard R30 : Logo for compatible services
Gustard R30: CelWare 3.x
Based on an audio-optimised Linux kernel, the R30's CelWare 3.x software supports various protocols such as Roon Bridge, AirPlay, HQPlayer NAA, UPnP, Spotify and more. Users can enable or disable these features via a browser by simply entering the address “//x30.local”.
Gustard R30: Interface XMOS
The Gustard R30 is equipped with an XMOS XU216 USB interface, supporting signals up to PCM 768kHz and DSD512, for superior audio transmission.
Gustard R30 : XMOS interface
Gustard R30 : power supply stage
Gustard R30: Power supply
The R30 has two separate transformers to power the digital and analogue sections separately, eliminating any interference. Each channel is also equipped with dedicated filter capacitors, ensuring stable voltage and noise-free operation.
Gustard R30: I2S pinout
Gustard R30 : I2S pinout diagram
Product typeDAC
Preamplifier
Streamer
Inputs1x USB-B
1x RJ45
1x HDMI I2S
1x HDMI I2S-G
1x Coaxial
1x AES/EBU
1x Optical Toslink
1x MicroSD card
1x BNC clock input (50Ω)
1x USB-C (Update Firmware)
1x Balanced stereo XLR
DAC27bit R2R
USB interfaceXMOS XU216
Supported sampling ratesUSB / RJ45 : PCM up to 32bit 768kHz / DSD DOP256 / Native DSD up to DSD512
Coax / AES / Optical : PCM up to 24bit 192kHz / DSD DOP64
I2S : PCM up to 32bit 1536kHz / DSD DOP512 / Native DSD up to DSD1024
Network protocolsRoon Bridge
Airplay
HQPlayer NAA
UPnP
mC Mconnect
Bubble UpnP
Spotify
QQMusic
Output levelRCA : 2.5Vrms (fixed volume)
XLR : 5.1 Vrms (fixed volume)
Frequency response20Hz-20kHz (±0.2dB)
Dynamic range>123dB
Signal-to-noise ratio (SNR)>121dB
Crosstalk-139dB @10kHz
Total harmonic distortion more noise (THD+N)≤0.00145% @1kHz
Intermodulation (IMD)≈0.002% @-1dBFS
Output impedance100Ω
TriggerInput
Output
Power supply voltage115V/230V AC 50Hz/60Hz (Selectable)
Consumption< 35W
Dimensions430 x 300 x 80mm
Package1x Gustard R30
1x Remote control
1x Power cord
InputRJ45
InputSD Card
InputClock (BNC)
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipR2R LADDER DAC
Max sampling rate1536kHz
Max sampling rateDSD1024
ClassClass A / AB
NetworkingYes
Remote ControlYes
Streaming services & Network protocolsQQMusic
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsUpnP
Streaming services & Network protocolsBubble UpnP
Streaming services & Network protocolsHQPlayer NAA
Streaming services & Network protocolsmC Mconnect
GUSTARD R30 DAC R2R Preamplifier Streamer 32bit 1536kHz DSD1024 Black
The Gustard R30 is a DAC, streamer and preamplifier based on an R2R ladder resistor network to offer high-precision digital-to-analogue conversion,...
