TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Silver
Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198 chips. These enable it to support high sample rates up to 32bit 384kHz PCM and DSD256, while offering incredible performance in terms of distortion level, THD+N and dynamics.
Reference : 15170
299,00 €tax incl.
249,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Topping D30 Pro
Topping D30 Pro DAC Symétrique 4x CS43198 32bit 384kHz DSD256 Argent
Quad CS43198 DAC
The use of four Cirrus Logic CS43198 digital-to-analog conversion chips provides a total of 8 balanced channels. This special design provides the DAC with greater output capacity while improving overall sound quality and measured performance.
XMOS USB Interface
The D30 Pro uses an 8-core XMOS XU208 chip for its USB interface. This supports high-resolution files up to 32bit 384kHz PCM and DSD256. In addition, the D30 Pro uses a custom Thesycon driver for optimal performance.
Complete connections
The D30 Pro will adapt to any system, with a complete range of inputs: USB-B, Toslink Optical, Coaxial and RCA stereo. It offers both unbalanced stereo RCA and balanced XLR outputs.
High quality components
The Topping D30 Pro benefits from careful design in every respect. It uses an Altera PLC for clock signal processing and eight independent LDOs to provide a clean and stable power supply for the audio circuit.
Topping D30 Pro DAC Symétrique 4x CS43198 32bit 384kHz DSD256 Argent<span id=" />
Topping D30 Pro review by Audio Science Review (Amir)
" Consistent with tradition, Topping D30Pro produces excellent objective resultsNeedless to say, I am happy to strongly recommend the Topping D30Pro DAC. "
Test du Topping D30 Pro par Audio Science Review (Amir)
Product typeDAC
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x Stereo RCA
1x Balanced stereo XLR
DAC Chips4x Cirrus Logic CS43198
Sampling ratesUSB : PCM up to 32bit 384kHz
Native DSD up to DSD256, DSD DoP up to DSD128
Coaxial / Optical: PCM up to 24bit 192kHz, DSD64 (DoP)
THD+N @ A-WeightingRCA : < 0.0001% @ 1kHz
XLR : < 0.00009% @ 1kHz
THD @ No-Weighting 45kBwRCA : < 0.0004% @ 20Hz-20kHz
XLR : < 0.0004% @ 20Hz-20kHz
SNR @ A-WeightingRCA : 127dB @ 1kHz
XLR : 132dB @ 1kHz
Dynamic range @ A-WeightingRCA : 127dB @ 1kHz
XLR : 132dB @ 1kHz
Frequency responseRCA : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
XLR : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
Output voltageRCA : 2Vrms @ 0dBFS
XLR : 4Vrms @ 0dBFS
Noise @ A-WeightingRCA : < 0.9µVrms
XLR : < 1.1µVrms
CrosstalkRCA : -116dB @ 1kHz
XLR : -145dB @ 1kHz
Output impedanceRCA : 20Ω
XLR : 40Ω
Dimensions174 x 138 x 45mm
Weight870g
Housing materialAluminum
Package1x Topping D30 Pro
1x Remote control
1x Power cable
1x USB Cable
DAC / ADC ChipCS43198
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Remote ControlYes
2 reviews
A matter of taste
Great DAC, measures excellent and sounds very refined. From my experience it fits systems rather with relaxed highs because this kind of Cirrus-based DAC has it's own clarity. Mid region, mid tones and vocals aren't that emphasized like with an AKM DAC, bass is well-controlled. Top quality overall and the simultaneous use of XLR and RCA outs make this an amazing "preamp" too (in PRE-mode) for e.g. a 2.1/2.2 system (where you feed your sub/subs from the RCA outs while main system is fed from XLR). All-in-all, a neutral, precise sound without much emotion. It just doesn't has its own sound. Some people like this, some not. A matter of taste. For us it lifted a bit on the highs which came very handy so we give it 5 stars.
This review has been posted for TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Silver
Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198...
