By buying this product you get 399 loyalty points
The Hibiki SDS is a dual-mono R2R DAC with the almost unique function of being able to upscale the sampling rate of any source in DSD1024 in order to offer a signal with the highest possible resolution when converted by the resistor network. In short, the very best in digital signal processing at the service of pure analogue conversion.
As we said earlier, the Hibiki SDS is capable of upscaling the sampling rate of any source in DSD1024. To achieve this, a Delta-sigma modulator is used to apply 5-bit modulation to the incoming signal (a DSD signal is conventionally processed at 1bit) in order to obtain a signal quantization worthy of a much higher sampling rate. This, combined with reverse-engineering of the way the DSD format works, means that any sampling rate can be converted directly into DSD1024. For example, the Hibiki SDS can directly upscale a DSD128 file to DSD1024 without first undergoing PCM conversion and without any loss of information.
Once the signal has been upscaled to DSD1024, it is converted to an analogue signal using a ladder network of 36 resistors. Although a network of 32 resistors would technically have been sufficient for the conversion, Hibiki decided to add 4 extra resistors to produce 10% more information to compensate for any potential desynchronisation coming from other resistors. The result is a precise reproduction with a transparent, airy soundstage.
Although the technological heart of the Hibeki SDS DAC is DSD1024 signal upscale, it has also been designed for those who wish for a signal with as little digital processing as possible. With this in mind, a NOS (Non-oversampling) mode is available to produce the most faithful reproduction of the base file possible; this mode is used by default when the PLL diode on the front panel is not lit. Furthermore, the analogue part of the Hibiki SDS uses an architecture without feedback loops for the most natural sound possible.
To provide the best possible power supply for their DAC, Hibiki has adopted a power supply architecture that allows total isolation of the power supply from the conversion circuit. The result is an ultra-quiet -150dB power supply. Finally, although the Hibiki SDS has its own internal custom clock, it is compatible with external WCK and MCK clocks if you wish for it to be synchronised with other equipment.
Product type | DAC |
Inputs | 1x AES XLR 3-pin 1x Coaxial 1x Optical Toslink 1x BNC 1x Input for external clock 1x USB-B 1x HDMI I2S |
Outputs | 1x XLR 3-pin stereo 1x RCA stereo |
Supported sampling rates | USB : up to PCM384/DSD512 I2S : up to PCM768/DSD1024 AES/Coax/Toslink/BNC : up to PCM192/DOP64 |
Output level | XLR : 4.6Vrms RCA : 2.3Vrms |
Power supply | 250V |
Weight | 8kg |
Color | Black |
Package | 1x Hibiki SDS |
Input | I2S via HDMI |
Input | AES/EBU |
Input | USB |
Input | Optical |
Input | BNC |
Input | Clock (BNC) |
Input | SPDIF |
Output | RCA |
Output | XLR |
Max sampling rate | DSD1024 |
Color | Black |
Networking | No |
Remote Control | No |
