XDUOO X5 Digital Audio Player
The DAP xDuoo X5 is a digital music player based on two CS43131 DAC chips in a balanced architecture. These DAC chips give it the ability to support high-resolution sampling rates up to PCM 32bit 384kHz and DSD256.
Reference : 20579
219,00 €tax incl.
182,50 € tax excl.
xDuoo X5 Digital Audio Player DAP 2x CS43131 Bluetooth LDAC 32bit 384kHz DSD256
XDUOO X5 picture
The DAP xDuoo X5 is a digital music player based on two CS43131 DAC chips in a balanced architecture. These DAC chips give it the ability to support high-resolution sampling rates up to PCM 32bit 384kHz and DSD256. On top of this come a host of features such as bi-directional Bluetooth 4.2 (AAC, SBC, LDAC), a microSD slot for up to 1TB (microSD card not included), 10-band equalization, an “IN-CAR” mode and USB DAC functionality. All this is accessed via a handsome 3.5” HD IPS display, and, on the connectivity side, there's a USB-C port (power and DAC) as well as 3 outputs: 3.5mm line output, single-ended jack 3.5mm headphone output and balanced jack 4.4mm headphone output. The xDuoo X5's power supply is based on a 2600mAh battery offering up to 10h of autonomy with a full charge time of 3h, making it a perfect ally for everyday use or travel.
XDUOO X5 highlights
xDuoo X5: 2x CS43131 balanced DAC
The xDuoo X5 features two CS43131 DAC chips implemented within a balanced architecture. This enables it to support sampling rates up to PCM 32bit 384kHz and DSD256. Furthermore, its USB port enables it to operate as a USB DAC for easy enjoyment of high-resolution files.
XDUOO X5 DAC
XDUOO X5 Bluetooth functionality
xDuoo X5: Bi-directional Bluetooth 4.2
The xDuoo X5 benefits from bi-directional Bluetooth 4.2 functionality supporting AAC, SBC and LDAC codecs for reliable, stable wireless signal reception and transmission.
xDuoo X5: a host of features
MicroSD 1TB
MicroSD 1TB
The xDuoo X5 features a MicroSD slot for adding up to 1TB (microSD card not included) of memory, so you can enjoy an extensive music library.
10 band EQ
The xDuoo X5's 10-band equalization allows each frequency band to be precisely adjusted to suit both hardware and user taste.
"IN-CAR" mode
IN-CAR mode
By connecting the X5's USB port to your car, you can synchronize its use with your car and provide high-quality audio sources.
DAP xDuoo X5 overview
13.5” HD IPS display
2MicroSD slot
3Power button
4Volume control
5USB-C port (charge/DAC)
6Jack 3.5mm line output jack
7Single-ended Jack 3.5mm headphones output
8Balanced Jack 4.4mm headphones output
Product typeDAP
DAC chip2x CS43131
Inputs1x USB-C (DAC)
1x 1TB microSD slot
Bluetooth
Outputs1x Balanced 4.4mm jack headphones output
1x Single-ended 3.5mm jack headphones output
1x AUX jack 3.5mm output
Bluetooth
Supported sample ratesPCM up to 32bit 384kHZ, native DSD up to DSD256
Supported Bluetooth codecsSBC, AAC, LDAC
Suppoted formatsDSD64-256 (DSF, DFF, ISO), WAV, AIFF, FLAC, APE, MP3, WMA, OGG, M4A, AAC
MicroSD supportUp to 1TB (FAT32, EXFAT, NTFS)
USB DACPlug and play
Compatible output impedance16-300 ohm
DisplayHD IPS 3.5" (480x800px)
Single-ended Jack 3.5mm headphones output specifications
Output power200mW (32 ohm / THD+N <0.001%)
Frequency response20Hz-20kHz (+/-0.5dB)
SNR≥ 115dB
Crosstalk> 75dB
THD+N0.001% @ 1kHz (32 ohm @ 1kHz)
Balanced Jack 4.4mm headphones output specifications
Output power270mW (32 ohm / THD+N <0.001%)
SNR≥ 120dB
Crosstalk> 115dB
THD+N0.0009% @ 1kHz (32 ohm @ 1kHz)
3.5mm line output specifications
Output level2.0Vrms
SNR≥ 115dB
Crosstalk> 108dB
Power supply5V DC via USB-C
Battery3.7V/2600mAh lithium polymer battery
Battery life10h
Charging time3h
Dimensions105 x 60 x 16mm
Weight150g
ColorGrey
Package1x xDuoo X5
1x USB Cable
InputWiFi
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
ColorGray
XDUOO X5 Digital Audio Player DAP 2x CS43131 Bluetooth LDAC 32bit 384kHz DSD256
The DAP xDuoo X5 is a digital music player based on two CS43131 DAC chips in a balanced architecture. These DAC chips give it the ability to...
