Apporte un vrai plus , plus d’ouverture , scène plus ample , pas d’agressivité ni effondrement de la dynamique, un petit rodage et que du bonheur
No featrued products
This cable IS NOT compatible with the following power supply references: 8718/14183/9646/8817/9575/9645/13387/11501/9644
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. This cable is designed with a Sommercable Meridian SP215 cable made of OFC copper conductors with a section of 1.5mm², ensuring an excellent electrical conductivity. It is terminated with Viborg DC25G and GX16G connectors with gold-plated copper alloy contacts, maintaining a very good level of conductivity while ensuring a high resistance to oxidation. The cable is finally covered with a beautiful black and grey braided sheath from Viablue.
This cable is only compatible with LHY power supplies.
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
| Specifications | |
| Product type | Power cable |
| Length | 1m |
| Connectors | 1x GX16 1x Jack DC 5.5/2.5mm |
| Cable conductors material | OFC Copper |
| Cable conductors section | 2x1.5mm² |
| Cable diameter | Ø8mm |
| Connectors contacts plating | Gold |
| General | |
| Cable color | Black and grey |
| Connectors color | Grey |
| Length (m) | 1.0 |
| Shielding | NC |
| Section (mm²) | 1.5 |
| Connector | Jack DC |
| Connector | GX16 |
| Conductors Plating (Cable) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Hugues E.
