Power Cable GX16 to Jack DC multi-ended 5.5/2.5mm and 5.5/2.1mm 1m
This affordable, high-quality power cable features a 2-pin GX16 female connector (also known as an aviation connector) and a DC 5.5/2.5mm and 5.5/2.1mm jack connector. This cable ensures excellent electrical signal conductivity for powering your devices or modules.
Reference : 18590
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 03-06-2025.
Power CableGX16 to Jack DC multi-ended 5.5/2.5mm and 5.5/2.1mm 1m
Photo of GX16 to DC jack power cable
This affordable, high-quality power cable features a 2-pin GX16 female connector (also known as an aviation connector) and a DC 5.5/2.5mm and 5.5/2.1mm jack connector. This cable ensures excellent electrical signal conductivity for powering your devices or modules. A red and black nylon sheath protects the cable. This sheath ensures good flexibility and resistance to mechanical stress.
Positive pole: GX16: Pin 2 -> Pin Central on DC jack
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain products. Using a non-compatible cable could destroy your equipment.
Connection diagram for the GX16 connector on this power cable
This cable is not compatible with the following Audiophonics linear power supplies (different polarity) :
AUDIOPHONICS Double Regulated Linear Power Supply 5V / 12V 30W T-Amp V-DAC2 LT1085
AUDIOPHONICS Double Regulated Linear Power Supply USB 2x 5V 1.5A 7.5W LT1086
Product typePower câble
ConnectorsGX16 female 2-pole
Conductors materialCopper alloy
SheathNylon
Cable length1m
ColorBlack and red
Weight48g
Package1x Power cable GX16 to DC jack 5.5/2.5mm and 5.5/2.1mm
Length (m)1.0
ShieldingNC
Section (mm²)N/A
ConnectorJack DC
ConnectorGX16
Conductors material (Cable)Copper Alloy
Cable not work at linear Power12 v
This Cable not works with my linearPowersupply 12 V 5A
This review has been posted for Power Cable GX16 to Jack DC multi-ended 5.5/2.5mm and 5.5/2.1mm 1m
This affordable, high-quality power cable features a 2-pin GX16 female connector (also known as an aviation connector)  and a  DC...
