DD TC100S USB-C Female to Coaxial Female Interface 75 Ohm 24bit 192kHz
The DD TCA100-COA is a high quality USB-C to coaxial adapter that provides USB connectivity to older DACs and amplifiers that have a digital coaxial input. It is then possible to connect to your devices more recent peripherals via a USB connection.
Reference : 17654
52,90 €tax incl.
44,08 € tax excl.
Last items in stock !
Shipping date: 25-07-2025.
DD TCA100S
Interface USB-C Female to Coaxial Female Copper OCC 75 Ohm 24bit 192kHz
DD TC100-COA Female USB-C to Male Coaxial Interface OCC Copper 75 Ohm 24bit 192kHz 35cm
The DD TCA100S is a high quality USB-C to coaxial adapter for providing USB connectivity to older DACs and amplifiers that do have a coaxial digital input. It then becomes possible to connect more recent peripherals to your devices via a USB connection. Especially ideal for using a current smartphone as a source. The female Coaxial output can support PCM audio streams up to 24bit 192kHz.
Quality components and a compact size
The TCA100S is equipped with a DA101C digital audio transformer from Murata. This ensures a balance between the USB input circuit and the coaxial output circuit for optimal transmission.
Technical Characteristics
Product typeUSB / Coaxial digital interface
Connectors1x Coaxial Femelle
1x USB-C Femelle
Supported sample ratesPCM 24bit 192kHz
Dimensions85 x 20 x 12.5 mm
Weight18g
ColorVert
OutputCoaxial SPDIF
Max sampling rate192kHz
ColorGreen
Interface chipMurata DA101C
The DD TCA100-COA is a high quality USB-C to coaxial adapter that provides USB connectivity to older DACs and amplifiers that have a digital...
