SINGXER SU-2 USB Digital Interface 32bit 768khz DSD1024 SPDIF AES/EBU I2S HDMI LVDS
Here is the second version of SINGXER SU digital interface. It gains more computation power and can now handle digital streams up to 768kHz 32-bit PCM & DSD1024 - namely thanks to the introduction of ultra-high precision Accusilicon clocks.
4.4 / 5
By buying this product you get 39 loyalty points
Reference : 14270
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 05-06-2025.
SINGXER SU-2
USB interface 32bit / 768kHz DSD-1024 Coaxial AES / EBU LVDS HDMI I2S
As any true platform for digital audio connectivity, SINGXER SU-2 significantly expands the scope of your USB  digital sources (PC, streamers, smartphones etc ...) and allows a connection via SPDIF (coax), I2S (LVDS HDMI), or even AES / EBU to your DAC, DSP or FDA.
Its electronic components as well as its architecture (FPGAs with dual clock) allowing it to offer high-performance audio while covering all requirements for a connection within a high-fidelity system.
It also features a complete isolation (150 Mbps isolation chip) to cancel any interference if the source does not already have an isolated USB connector. The isolation chip itself is then corrected by a FPGA circuit in order not to cause additional jitter during the operation.
Accusilicon High Fidelity Oscillators
The main novelty of this second versiojn rests in the use of a pair of Accusilicon clocks.
This extremely -ow phase noise crystal oscillator (less than 90dBc @ 10Hz) is intended for professional recording equipment as well as audiophile electronics. These models offer a remarkably low jitter rate measured 0.2ps on 10Hz-1MHz band and 0.071ps on 12-80MHz band.
This is a reference component in the audiophile world beacause of its excellent precision and stability.
Input and output for clock signals
To go even further, the SU-2 provides a clock input (10 MHz) on standard 50Ohm socket compatible with most of the TC clock, GPDSO, and even atomic clocks models. In this mode, the SU-2 can also function as a frequency converter (10 MHz to 44.1 - 384kHz).
Reciprocally, the device is able to export its own clock output via a SP/CLK (BNC) connector. It can thus operate in master mode for any device with a clock input. In its autonomous clock mode, the SU-2 in Singxer is capable of generating a clock signal of 44.1 kHz to 384kHz (sample clock) or a signal to 22.5792Mhz 49.152Mhz (master clock). The circuit enables its standalone external clock mode whenever the USB connector is disconnected.
Product typeUSB digital interface
Sampling rate supportedPCM via SPDIF & AES / EBU: Up to 192kHz
PCM via I2S & WCLK: Up to 768kHz
DSD via SPDIF & AES / EBU: DSD64 DoP Fashion
DSD via I2S: native DSD1024
FPGAXilinx
Clocks2x Accusilicon
Input1x USB 2.0-B (Driver available for download from this sheet))
1x Clock 10MHz
Outputs1x Coaxial SPDIF (RCA)
1x BNC
1x I2S through HDMI
1x AES / EBU
1x MCLK / WCK (clock)
OS compatibilityWindows XP, 7, 8, 10 - Installing drivers needed
MacOS 10.6 and later
Linux with kernel UAC2
Android 4.2 and later - Supports OTG function
I2S compatibilityAudio-GD: Support native DSD / DoP (all switches OFF)
Holo Audio: Support automatic detection and DSD (all the switches OFF)
PS AUDIO: Support automatic detection and DSD (all the switches OFF)
Gustard (3/6 Switch ON)
DimensionsWidth: 233mm
Depth with connectors: 185.6mm
Without connectors: 170mm
Height with legs: 58.4mm
Without legs: 46.5mm
OutputOptical Fiber
OutputI2S LVDS via HDMI
OutputCoaxial SPDIF
Max sampling rate768kHz
Max sampling rateDSD1024
Interface chipNC
7 reviews
Interface digitale excellente.
Cette interface outre sa qualité de fabrication s'avère très performante. Sa connectique est bien fournie. Elle alimente un dac "Lake People RS6 via la prise AES/EBU". Je l'ai raccordée à l'ordinateur sur une prise USB C par l'intermédiaire d'un câble en argent pure Ataudio silver USB C vers USB B. Le résultat est à la hauteur, musicalité, dynamique, précision du grave à l'aigu. Bref je ne regrette pas l'achat.
This review has been posted for SINGXER SU-2 USB Digital Interface 32bit 768khz DSD1024 SPDIF AES/EBU I2S HDMI LVDS
singxer su2
my no. 2 singxer su2
should it use that experiment
changed Capacitors to os-con
and changed the 5 volt power supply to ifi power elite
and a 10mhz master clock
sounds more like 3d
much better treble and midrange
singxer su2 sounds fantastic in itself
one of the best usb interface
Plus de finesse et de spatilalisation ( très structurée en largeur et en profondeur),que sur mon hécate et ce sans aucun rodage. ( en liaison rca numérique réal cable)
Après 50h, toujours les mêmes qualités et avec un gain en plénitude de timbre, sans lourdeurs ,chaleureux et léger.. En passant de la liaison rca à la liaison XLR, ( Canard audiophonics) les mêmes gains s accroissent. Très bel ensemble qui rapproche un peu plus de la musique vivante
S accroissent significativement ; c est impressionant
Déception
Grosse déception, pourtant utilisé avec un Dac de la même marque Singxer, attenuation du signal sonore de 15 db ce qui est énorme.
singxer su2, is a good digital interface, for usb
good sound, high resolution, and is soft in sound in high, good midrange
you get details, with as well as a little more 3d.
I have a neumann 310a studio monitor.
they reveal everything in the sound.
running my hifi system, with dac from gustard x20pro
with earth and power cable put ferrite core on
gives something extra to, singxer su2 power supply, clean power
Here is the second version of SINGXER SU digital interface. It gains more computation power and can now handle digital streams up to 768kHz 32-bit...
