No featrued products
Brass plated connector ⌀4mm
This 2.5mm jack connector with a neat carbon finish is built with gold-plated brass conductors within a painted metal capsule. It offers good conductivity and mechanical resistance.
Its structure is TRRS (Tip - 2x Ring - Sleeve). It can thus be used to build a very compact 3 channels connector.
The base of the cable.is protected thanks to a silicon sleeve that protects the cable conductors against twisting and strong pull.
| Specifications | |
| Jack Format | 2.5mm |
| Contacts materials | Brass |
| Plating | Gold |
| Max cable diameter | Ø 4mm |
| Connection Type | Welding |
| Weight | 5g |
| Body dimensions | ⌀8.42 x 22.5mm |
| Total length | 37.3mm |
| Color | Black |
| Max cable diameter (mm) | 4.0 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts number | 4 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
