No featrued products
This IEC Lock connector in angled IEC C13 format offers an innovative solution designed to ensure secure, reliable connection of power cables. An effective locking system prevents cables from accidentally detaching from the devices to which they are connected. IEC Lock connectors are fully compatible with standard IEC connectors and require no additional modifications or special cables. Mounting is simple, with a screw-on system that requires no soldering.
| Specifications | |
| Product type | Lockable IEC C13 connector |
| IEC format | Angled IEC C13 |
| Shell material | Nylon LSZH |
| Min/Max conductors section | 0.75mm² - 1.5mm² (14AWG - 18AWG) |
| Max cable diameter | Ø8mm |
| Voltage / Current | 250V 15A |
| Operating temperature range | -25°C / +70°C |
| Certifications | KEMA ENEC 05 UL |
| General | |
| Dimensions | 60.5*38*21mm |
| Color | Black and red |
| Max cable diameter (mm) | 8.0 |
| Mounting type | To screw |
| Connectic | Female |
| Connector | IEC C13 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | N/A |
| Rated current (A) | 15.0 |
