No featrued products
Schuko F-Type 230V 16A Ø16mm
This low-cost Schuko power connector is ideal for designing your own power supply cables without breaking the bank. The practical rubber tip of this model can be cut according to the diameter of your cable, up to 16mm. It also allows a good hold of your cable in the connector.
APlease note that this connector is only compatible with German schuko plugs, which are grounded on the side of the plug.
| Specifications | |
| Product type | Schuko power connector F-Type |
| Max cable diameter | Ø16mm |
| Mounting type | To screw |
| General | |
| Body material | Plastic |
| Total dimensions | Ø42 x 103mm |
| Color | Black |
| Max cable diameter (mm) | 15.0 |
| Connectic | Male |
| Connector | Schuko |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
| Rated current (A) | 16.0 |
