DAYTON AUDIO MX12-22 Speaker Driver Subwoofer 600W 4 Ohm 89dB 23Hz-450Hz Ø30.5cm
Designed to produce maximum output at an unbeatable price, this MX12-22 Max-X dual voice coil subwoofer from Dayton Audio has all the features you'd expect from a top-of-the-line model. Offering remarkably low distortion, the MX12-22 is designed to be used in compact enclosures, making it ideal for home and car audio systems. With its 27.4mm peak-to-peak excursion, this speaker is capable of moving large amounts of air.
By buying this product you get 22 loyalty points
Reference : 15554
229,00 €tax incl.
190,83 € tax excl.
This product is temporarily unavailable.
Dayton Audio MX12-22
Dayton Audio MX12-22 Haut-Parleur Subwoofer 600W 4 Ohm 89dB 23Hz-450Hz Ø30.5cm
Performances & Design
In designing the MX12-22, Dayton Audio did everything possible to reduce the final price without sacrificing performance or reliability. A large, inverted dust cover completely covers the paper pulp diaphragm to create an extremely rigid, design-led layered diaphragm. The narrow but tall, custom-molded bowl has been optimized to allow for significant excursion without reducing the diaphragm's surface area to ensure maximum displacement with improved efficiency. In addition, the suspension wraps around the back side of the mounting ring for maximum bonding surface area to easily withstand the stresses of high excursion. To maintain diaphragm linearity, the MX12-22 uses dual spiders, with enough spacing to ensure that there is no vibration even when pushed to its limit.
Efficient venting system
High efficiency subwoofers can generate a lot of heat. Excessive heat build-up increases the overall temperature, which in turn increases the resistance. This leads to reduced efficiency, power compression and premature failure.
The MX12-22 has everything it takes to move as much air as possible through its 63.5mm coil to dissipate that excess heat. Six large-diameter vents combined with a flared vent at the pole piece create a continuous airflow directly through the center of the coil. The outside of the coil is cooled by eight vents under the frame and six peripheral vents through the back plate. All of this airflow not only minimizes power compression, but also makes the MX12-22 extremely quiet, even at high excursion, virtually eliminating the mechanical noise often found in today's subwoofers.
A powerful motor for incredible flexibility
Another common problem with many of today's budget subwoofers is the lack of motor power. This leads to speakers that are inefficient or only capable of producing poor quality bass.
The massive double-stacked ferrite magnets have been optimized to efficiently drive the coil with high precision. In addition, the magnetic gap is narrow enough to ensure very low magnetic force loss. This powerful assembly gives the MX12-22 an impressive BL of 18.2T/m with a Qts of 0.46, allowing it to be used in compact closed or open cabinets with excellent low frequency extension.
Finally, with its dual 2Ω coils, the MX12-22 can be used in many configurations to ensure maximum performance from your amplifier in any application. In most home audio systems, the coils will be wired in series for a 4Ω load. In the case of a car system, the coils can be run separately for a dual 2Ω load or wired in parallel at 1Ω to draw maximum power from high current amplifiers.
An excellent performance/price ratio
With extensive optimization and advanced design, the Dayton Audio MX12-22 is a high-performance subwoofer with a low price tag, incredible output capacity and low distortion. It's an ideal choice for a powerful home stereo speaker design, a high-quality mobile audio system, or a car system that delivers great sound quality.
Dayton Audio MX12-22 Haut-Parleur Subwoofer 600W 4 Ohm 89dB 23Hz-450Hz Ø30.5cm<span id=
Speaker driver typeSubwoofer
Nominal diameterØ30.5cm (12")
Power handlingRMS : 600W
Max : 1200W
Impedance4Ω
Frequency response23Hz - 450Hz
Sensitivity89.4dB @ 2.83V/1m
Voice coil diameterØ63.5mm (2.5")
Weight12.3kg
Total external dimensionsØ315.7 x 197.6mm
Thiele-Small Parameters
Resonant frequency (Fs)28.8Hz
DC Resistance (Re)3.95Ω
Voice coil inductance (Le)5.09mH
Mechanical Q (Qms)3.25
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.35
Compliance equivalent volume (Vas)45.59L (1.61ft.³)
Mechanical compliance of suspension (Cms)0.12mm/N
Force factor (BL)21.5T/m
Diaphragm mass inc. airload (Mms)252g
Max linear excursion (Xmax)15.5mm
Surface area of cone (Sd)514.7cm²
Materials
Cone materialPaper / Fiberglass
Surround materialRubber
Frame / Basket material Steel
Magnet materialFerrite
Mounting infoirmations
Total external diameterØ315.7mm
Cutout ciameterØ283.9mm
Depth197.6mm
Number of mounting holes8
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume21.24L (0.75ft³)
Sealed F360Hz
Vented volume45.31L (1.6ft³)
Vented F337Hz
Speaker Power (W RMS)600.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)305.0
Diaphragm typePaper
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)15.0
Lowest frequency (Hz)23
Highest frequency (Hz)450
Reçu, hauts parleurs de qualité !
Pas encore tester, produits de bonne qualité je recommande!
This review has been posted for DAYTON AUDIO MX12-22 Speaker Driver Subwoofer 600W 4 Ohm 89dB 23Hz-450Hz Ø30.5cm
Designed to produce maximum output at an unbeatable price, this MX12-22 Max-X dual voice coil subwoofer from Dayton Audio has all the features...
