DAYTON AUDIO RST28F-4 Speaker Driver Dome Tweeter Fabric 80W 4 Ohm 94dB 1400Hz - 20kHz Ø2.8cm
DAYTON AUDIO RST28F-4 Fabric Dome Tweeter 4 Ohm Ø2.8cm
The Dayton Audio RST28F-4 tweeter with fabric cone offers excellent performance, allowing frequencies from 1400Hz to 20kHz to be reproduced with both natural and dynamic sound.
Reference : 12865
44,90 €tax incl.
37,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
The Dayton Audio RST28F-4 tweeter with fabric cone offers excellent performance, allowing frequencies from 1400Hz to 20kHz to be reproduced with both natural and dynamic sound. Very well designed, this 2.85cm diameter loudspeaker has a motor with Ferrofluid cooling system and copper rings, ensuring great transparency in high frequencies. Belonging to the Reference Series of Dayton Audio, this RST28F-4 has the characteristics of a clean, detailed and transparent reproduction.
Speaker seriesReference Series
Speaker typeTweeter
Nominal diameter2.85cm (1.125")
Power (RMS)80W
Impedance
Sensitivity93.5dB @ 2.83V/1m
Frequency response1400Hz - 20kHz
DC Resistance (Re)
Voice coil inductance (Le)0.03mH
Resonant frequency (Fs)710Hz
Mechanical Q (Qms)2.52
Electromagnetic Q (Qes)1.46
Total Q (Qts)0.92
Surface area of cone (Sd)6.6cm²
Speaker Power (W RMS)80.0
Speaker TypeDome tweeter
Impedance (Ω)4
Loudspeaker diameter (mm)28.0
Diaphragm typeFabric
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)1400
Highest frequency (Hz)20000
Perfect
The best tweeter I've had. Much better than others much more expensive
This review has been posted for DAYTON AUDIO RST28F-4 Speaker Driver Dome Tweeter Fabric 80W 4 Ohm 94dB 1400Hz - 20kHz Ø2.8cm
The Dayton Audio RST28F-4 tweeter with fabric cone offers excellent performance, allowing frequencies from 1400Hz to 20kHz to be reproduced with...
