KECES P8 Ultra Low Noise Regulated Linear Power Supply 9 / 12V 8A + USB 5V 1A
-15%
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply features a neat design with a high quality toroidal transformer and separate ground.
Reduced price!
Reference : 14670
799,00 €tax incl.
-15%
679,00 €tax incl.
565,83 € tax excl.
Last items in stock !
Shipping date: 07-05-2026.
Keces P8
Keces P8 Alimentation Linéaire Régulée Ultra Faible Bruit 9 / 12V 8A + 5V 1A
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply features a neat design with a high quality toroidal transformer and separate ground. This internal design provides an ultra-low noise signal and cancels all "hum" at 50Hz and full load. The power supply also incorporates protection if the maximum temperature is exceeded. The power supply also incorporates over temperature protection. All components are housed in a robust and attractive black brushed aluminum case. The brand logo is stamped into the aluminum on the power supply cover. A screen on the front panel displays the voltage and the current delivered.
Adjustable output
If the Keces P8 is so interesting, it is because it has an output with adjustable voltage. A switch allows you to select an output voltage of 9VDC or 12VDC for a current of 8A. The P8 also has a USB connector delivering 5VDC 1A. The input voltage is also selectable (230V or 115V AC) thanks to a switch on the bottom of the unit, to adapt to the current delivered by your mains sockets.
Product typeRegulated linear power supply
Input voltage (switchable)AC 110V-120V 60Hz
AC 220V-240V 50Hz
Output voltage9VDC / 12VDC
Output current8A
USB Output5VDC 1A
Output connectorJack DC 5.5/2.5mm
Consumption200W (full load)
HousingBrushed Aluminum 4mm
Dimensions300 x 220 x 66mm
Weight6kg
Package1x Keces P8
1x Power cable
1x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm cable
1x Jack DC 5.5/2.1mm to Jack DC 5.5/2.5mm adapter
Protections
Output voltageOver voltage protectionUnder voltage protectionOver current protectionOver temperature protection
9V9.5V8.5V8.2A80°C
12V12.5V11.5V8.2A80°C
InputIEC C14
OutputJack DC 5.5/2.5mm
Output voltage (V)5.0
Output voltage (V)9.0
Output voltage (V)12.0
Output current (A)8.0
Input voltage (V)230.0
Input voltage (V)120.0
Power SupplyRegulated Linear Power Supply
Génial
Cette alimentation est génial, je viens de faire un bon en avant assez important niveau qualité audio sur mon lecteur réseau Antipode S30 grâce à elle, plus de dynamique, du silence en fond, un son plus naturel franchement je ne regrette pas mon achat et c’est en rodage en plus, je recommande fortement, jeté les alimentations à découpage et à deux balles qui sont si bruyantes et qui peuvent polluer les autres appareils aux alentour
This review has been posted for KECES P8 Ultra Low Noise Regulated Linear Power Supply 9 / 12V 8A + USB 5V 1A
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The...
